Hi everyone,
I am very new to the whole idea building PCs and I recently decided to go all out and build my own gaming PC but had a few concerns about cooling. I plan on using the following
CPU: i7 5820K
GPU: 2 MSI GTX 980 in SLI
Motherboard: MSI X99S Gaming 9 AC
RAM: 32 GB G.SKILL RIPJAWS Z Series
Storage: Samsung 850 Pro SSD (256GB and 1TB)
Cooling (concern): Corsair H110 CPU Cooler
PSU: Corsair RM1000
Case: NZXT H440
I do not plan on any overclocking atm because of my lack of knowledge on the subject. My main concern is my PC overheating due to using sli in a mid tower case. I like the look of the H440 but I am willing to get a bigger case for better performance if need be. Are there any better cooling options than what I plan to use? I also had a question on whether Noctua or Corsair case fans perform better. Anyone willing to give me advice please do so and thank you
https://linustechtips.com/topic/311341-possible-overheating/
Hi everyone,
CPU: i7 5820K
PSU: Corsair RM1000
Case: NZXT H440
Try these fans, many have praised how quiet they are and how much air they draw in and how much air they push out. I just ordered 3 of them but in white. But before you do that, try removing the front and top panels and see where the temperatures go. Make sure there is good push/pull pressure
Main Rig
Case: NZXT H440 White | CPU: Intel Core i5-4690K @5.2GHz | CPU Cooler: Corsair H80i Hydro Series | Motherboard: MSI Z97S Krait Edition | RAM: HyperX Fury White & Black Series 16GB (4x4GB) OC to 2133MHz | Graphics Card: Zotac GeForce GTX 980 Ti ArcticStorm | SSD: Intel 730 Series 480GB & Samsung 840 256GB | HDD: Seagate Barracuda 2TB 7200rpm | PSU: EVGA 750W Supernova G2 80+ Gold | Display: BenQ XL2420G & Samsung S20D300 | Headset: Corsair 1500 | Mouse: Logitech G700S | Keyboard: Corsair Vengeance K70 Silver RED LED
 XENON Build:
Intel Xeon E3-1230 V2 @3.3GHz | Intel DZ68BC | Corsair Dominator Platinum 2x4GB 1866MHz | Kingston HyperX 3k 240GB | MSI GeForce GTX 680 | Fractal Design Define R4 Titanium Grey | Seasonic 520W 80+ Platinum Fanless
Office Build:
Case: Fractal Focus G White | CPU: i5-8600K | CPU Cooler: Cooler Master Hyper 212 Evo | Motherboard: MSI Z370-A PRO | RAM: Corsair LPX 16GB-2666 | GPU: MSI GTX 1060 6GB GAMING X | SSD: Kingston A400 240GB | HDD: Seagate Barracuda 2TB 7200rpm | PSU: EVGA BT 450W+ Bronze
Phone
iPhone XS Max 512GB Gold
https://linustechtips.com/topic/311341-possible-overheating/#findComment-4231706
airflow is everything. The H440 isn't exactly built for high airflow, but with some decent fans like the ones mentioned above you'll be fine. Just don't sandwich the cards directly together. Btw, if you're actually going to build that beast make sure to take pictures and post a build log  ;)
https://linustechtips.com/topic/311341-possible-overheating/#findComment-4231758
