So I'm starting my overclocking with 4.6Ghz @ 1.35v (Ring Bus 4.5Ghz @ 1.3v) and VCCIN (Input Volts) @ 1.9v.
I have about a 9°C range in core temps from the first to fourth core. My temps are getting a little toasty too. I know they will at this voltage but should I be getting lower temps with my Enermax Liqtech 240mm? (RealTemp Snapshot Below)
New Post Down @ Bottom Of Page
Work Desktop | CPU: Intel Core i7 4770k | GPU: Quadro K1200 | Motherboard: EVGA Z97 Classified | RAM: Corsair Dominator Platinum 32GB (4x8GB) DDR3-2133Mhz | PSU: Seasonic 750W SS-750KM3 80 PLUS Gold | STORAGE: WD 1TB Se Enterprise Grade Drive & Corsair Neutron NX500 400GB NVMe PCIe  | COOLER: Enermax Liqtech 240 -  5x Noctua NF-F12 iPPC 2000 PWM | CASE: Corsair 600C | OS: Windows 10 Pro | Peripherals: Logitech MX Master 2S -- Logitech K840 -- INTEL X520 10Gb NIC -- 3x Acer H236HL -- Build Log |
Work Server | CPU: Intel Xeon E5-2650 v3 | Model: Cisco UCS C220 M4 (SFF) | RAM: 64GB (4x16GB) Cisco (Samsung) DDR4 2133Mhz | STORAGE: 4x Cisco (Seagate) 900GB 10K 2.5" (RAID 10) - 2x 32GB Cisco FlexFlash Boot Drive (RAID 1) | OS: vSphere 6.7 Enterprise Plus U3 |
Laptop | CPU: Intel Core i7 6700HQ | GPU: Nvidia GTX 960M 2GB GDDR5 | RAM: 32GB (2 x 16GB) DDR4-2400Mhz | STORAGE: 512GB Hynix NVMe | OS: Windows 10 Pro |
Gaming Desktop | CPU: Intel Core i7 9700K | GPU: Gigabyte RTX 2080 WINDFORCE 8G  | Motherboard: ASRock Z390 PHANTOM GAMING-ITX | RAM: Ballistix Elite 32GB Kit (16GB x 2) DDR4-3000 | PSU: Silverstone SX700-LPT 700w 80 PLUS Platinum | STORAGE: 2x Samsung 970 PRO 1TB NVMe | COOLER: Noctua NH-L12 | CASE: Louqe Ghost S1 | OS: Windows 10 Pro | Build Log in Progress |
Home Server | CPU: Intel Xeon E5-2690 (Sandy Bridge) | GPU: Quadro P2000 | Motherboard: SUPERMICRO X9SRL-F  | RAM: 64GB (8x8GB) Micron VLP DDR3-1600 ECC | PSU: SUPERMICRO 665W 80 PLUS Bronze | STORAGE: 2x Samsung 860 EVO 500GB (RAID 1) - 4x WD 8TB Ultrastar (RAID 10) - Intel SSD D3-S4510 Series 240GB (BOOT)  | COOLER: Noctua NH-U12DXi4 with 2x Noctua NF-F12 iPPC 3000 PWM | CASE: SUPERMICRO CSE-842TQ-665B 4U | OS: vSphere 6.7 Enterprise Plus U3 | Build Log in Progress |
| Pixel 4XL 128GB - Clearly White - Unlocked - Carrier: Visible |
| F@H STATS |
https://linustechtips.com/topic/310994-overclocking-general-questions/
Welcome to HAswell non-refresh is all I can say. Its TIM is terrible so the temps are poor as well
RIG: I7-4790k @ 4.5GHz | MSI Z97S SLI Plus | 12GB Geil Dragon RAM 1333MHz | Gigabyte G1 Gaming GTX 970 (1550MHz core/7800MHz memory) @ +18mV(Maxed out at 1650/7800 so far) | Corsair RM750 | Samsung 840 EVO 120GB, 1TB Seagate Barracuda | Fractal Design Arc Midi R2 (Closed) | Sound Blaster Z        Getting: Noctua NH-D15 | Possible 250GB Samsung 850 Evo        Need a console killer that actually shits on every console? Here you go (No MIR/Promo)
This is why you should not get an FX CPU for ANY scenario other than rendering on a budget http://linustechtips.com/main/topic/286142-fx-8350-r9-290-psu-requirements/?p=3892901 http://linustechtips.com/main/topic/266481-an-issue-with-people-bashing-the-fx-cpus/?p=3620861
Wait isint the max recommended for the Hashwell series 80 degrees?
That's a personal thing really, I prefer sub 80 but it can handle up to 95 without serious degradation. I Personally don't recommend exceeding 85C MAX
I've reset the ring bus to stock and have changed some other settings. I'm gonna try 4.5Ghz Core
OC failed BTW
| F@H STATS |
@harrynowl
We need your input :D
pesonaly if the temps hit over 95C when stressing its a fail.
|King Of The Lost|
Project Dark: i7 7820x 5.1GHz | X299 Dark | Trident Z 32GB 3200MHz | GTX 1080Ti Hybrid | Corsair 760t | 1TB Samsung 860 Pro | EVGA Supernova G2 850w | H110i GTX
Lava: i9 12900k 5.1GHz (Undervolted to 1.26v)| MSI z690 Pro DDR4| Dominator Platnium 32GB 3800MHz| Power Color Red Devil RX 6950 XT| Seasonic Focus Platnium 850w| NZXT Kraken Z53
Unholy Rampage: i7 5930k 4.7GHz 4.4 Ring| X99
Rampage|Ripjaws IV 16GB 2800 CL13| GTX 1080 Strix(Custom XOC Signed BIOS) | Seasonic Focus Platinum 850w |H100i v2
Revenge of 775: Pentium 641 | Biostar TPower i45| Crucial Tracer 1066 DDR2 | GTX 580 Classified Ultra | EVGA 650 BQ | Noctua NH D14
@harrynowl
I went to 4.5Ghz and I'm still at 1.35v which is probably to much and I will move it down to probably somewhere around 1.33v but I'm already staying at and below 95°C
| F@H STATS |
I may have missed it in your OP but what program are you using to stress test?
While those temps are on the higher range you won't reach those in a 'normal' day to day scenario so you could run it.
Personally as long as all of my cores are averaging around 85c and only jumping to 90c in the test briefly that's fine.
do not use prime95 if thats what you are doing. the newest versions are very bad for the cpu and can do permanent damage to you cpu. i use intel burn in test or something like that.
Those temps are a little high but thats what you can expect from that cpu (had it too)
        wow... pretty empty here...
Intel ETU @ 4.5Ghz with 1.35v (Will prob be able to lower) I'm sticking around 83-87C with jumps to 93-96C
| F@H STATS |
That should be fine then. I'd work on getting the voltage as close to 1.3V as possible now :)
I was planning on trying it at this voltage for about 30 min intervals and dropping it .005 each time. Would you drop it in bigger intervals like .010?
| F@H STATS |
I'd go straight for 1.3v (unless you know it isn't stable at that) myself. If you know 1.3V wont work try 1.325 and work from there in 10mV intervals.
As I bench a lot of chips I like to find out quickly what works- so I just do 4.7/1.3 as my first clock to gauge the chip, it's more efficient than literally raising 100MHz and 5mV every time as you could be there a while.
I did 4.7Ghz @ 1.41v and it failed. I'll try 1.325v I'm almost positive it would fail at 1.3v
| F@H STATS |
Alright, best of luck :)
Could have been my ring bus OC that failed the other two settings. Do you overclock your ring bus at all or no?
| F@H STATS |
I tend to leave it until I know my core clock is stable. Reducing variables is a good way of getting the most accurate stability testing results.
Does an IGPU crash mean that I need to raise my core voltage a bit?
| F@H STATS |
