Pre-Built upgradability
Go to solution Solved by Ahaber,
The answer i'm trying to get is, can you upgrade pre built computers like that one. I just chose that one because it was cheap
Yes they can often be upgraded, but check to make sure that it has a 16x pcie slot before buying it.
I was thinking about buying a new computer for gaming and i was wondering of I could but a pre build computer from Costco, throw a graphics card into it and have it work because this is a lot cheaper than buying a full custom computer. In particular the computer I would buy is the Acer ATC-120-UC22 Desktop. Any help is welcome.
https://linustechtips.com/topic/310621-pre-built-upgradability/
^ I don't know WTF that guy is smoking thinking an A10 would bottle neck..
It would be fine. Don't expect to be the fastest.. But it would work.
You can upgrade drives, ram, gpu's and that is about it. Can change the mobo out for no real performance gains.
X-10 - 7980XE - Gigabyte Aorous Gaming 9 - 128GB GSkill TridentZ RGB - SLI Asus GTX 1080 TI Strix
Easy Desk GuideMalware Removal Guide - New mobo, Same OS Guide
https://linustechtips.com/topic/310621-pre-built-upgradability/#findComment-4222064
:)xD9_9:D:PB|
https://linustechtips.com/topic/310621-pre-built-upgradability/#findComment-4222078
Yes, you can upgrade, but the parts that it comes with may need to be replaced depending on how you want to upgrade. See my previous post.
https://linustechtips.com/topic/310621-pre-built-upgradability/#findComment-4222109
PCPartPicker part list: http://pcpartpicker.com/p/d4FrnQ
Price breakdown by merchant: http://pcpartpicker.com/p/d4FrnQ/by_merchant/
CPU: Intel Pentium G3250 3.2GHz Dual-Core Processor  ($64.95 @ Amazon)
Motherboard: Gigabyte GA-B85M-DS3H Micro ATX LGA1150 Motherboard  ($49.98 @ Newegg)
Memory: A-Data XPG V1.0 4GB (1 x 4GB) DDR3-1600 Memory  ($29.99 @ Newegg)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($54.99 @ Amazon)
Video Card: Sapphire Radeon R7 260X 2GB Video Card  ($89.99 @ Newegg)
Case: Silverstone PS08B (Black) MicroATX Mid Tower Case  ($30.98 @ Newegg)
Power Supply: EVGA 430W 80+ Certified ATX Power Supply  ($19.99 @ Newegg)
Operating System: Microsoft Windows 7 Home Premium SP1 (OEM) (64-bit)  ($15.00)
Total: $355.87
Generated by PCPartPicker 2015-02-14 23:16 EST-0500
My Build: 4690k @ 4.7 GHz, ASUS Strix 970 @ 1316 MHz, H105, Corsair Vengeance Pro @ 1600 MHz, H440, RM750
https://linustechtips.com/topic/310621-pre-built-upgradability/#findComment-4222136
Reminded me of this video:
But it's still a better idea to do it yourself as you KNOW what you're putting in your PC and you know that everything will work, what WILL bottleneck and what WON'T.
Only reason you stick a new GPU in a prebuilt is because you already bought a PC and don't have any more money for a new one. (Irony is that I described myself, look at sig and member title)
But if god forbid, you do go this route, make sure that it has a PCIe 16x slot, meets physical clearance requirements, and power requirements such as having the needed 6, 8, and/or 6+2 pins AND has the wattage to back everything up....
Follow the topics you create using the "Follow" button in the top right corner!
One day I will have my GTX 970. One day. PC specs are at my profile.
Not sure how to check what part works with what? Check out my compatibility guide!
https://linustechtips.com/topic/310621-pre-built-upgradability/#findComment-4222144
-snip-
-snip-
The fuck did you find a copy of Win 7 for 15 bucks?!
https://linustechtips.com/topic/310621-pre-built-upgradability/#findComment-4222156
460W http://www.tomshardware.com/answers/id-1780765/psu-dell-xps-8700.html
But if you have 700 bucks to throw around, you could do much better, like getting a much better GPU
https://linustechtips.com/topic/310621-pre-built-upgradability/#findComment-4222306
So I was just like you in my newbie days to PC lifestyle.
Quick answer, yes you can upgrade it, but you'll probably need a small graphics card to fit the case and maybe 8gb of RAM
But remember there not room for a lot of "big" upgrades but, surely you can upgrade it, any computer.
  MOBO: Gigabyte GA-Z170X Gaming 7 RAM: 16GB Corsair Dom.CPU: i5 6600k w/ H100i
 PSU: Corsair RM 850GPU:  GTX 980 Ti Case: NZXT 820 Full Tower
https://linustechtips.com/topic/310621-pre-built-upgradability/#findComment-4222416
My plans are to buy something like that and then buy a gtx 970 on amazon
https://linustechtips.com/topic/310621-pre-built-upgradability/#findComment-4225174
You could try this:
CPU: Intel Core i5-4690K 3.5GHz Quad-Core Processor  ($219.89 @ OutletPC)
CPU Cooler: Corsair H60 54.0 CFM Liquid CPU Cooler  ($54.99 @ NCIX US)
Motherboard: ASRock Z97E-ITX/ac Mini ITX LGA1150 Motherboard  ($109.99 @ Micro Center)
Storage: Samsung 840 EVO 120GB 2.5" Solid State Drive  ($88.98 @ OutletPC)
Video Card: Gigabyte GeForce GTX 970 4GB Video Card  ($328.99 @ Amazon)
Case: Cooler Master Elite 110 Mini ITX Tower Case  ($38.99 @ SuperBiiz)
Power Supply: Corsair Builder 500W 80+ Bronze Certified ATX Power Supply  ($39.95 @ OutletPC)
Operating System: Microsoft Windows 8.1 (OEM) (64-bit)  ($89.75 @ OutletPC)
Total: $1091.41
Generated by PCPartPicker 2015-02-15 16:40 EST-0500
it's very small, and has an SSD, just 4 gigs less of ram and no CD drive
https://linustechtips.com/topic/310621-pre-built-upgradability/#findComment-4227580
