everything seems to be connected, yes I have used it already and currently using a display port no adapters
Did you manage to get it working?
CPU: some amd thing Motherboard: its black RAM: its memory thats for sure GPU: r7 260x Case: corsair spec 01 Storage: 1tb of it PSU: 430w, so many watts
Display: its asus Cooling: fans Keyboard: logitech g710+ #browns4lyfe Mouse: its a logitech Sound: its what you hear Operating System: winders
https://linustechtips.com/topic/310618-pc-does-not-post/page/2/#findComment-4222485
nope doesnt even turn on anymore but still getting lights,  I know everything works, fans, psu, mobo were all on but didnt post
Hm maybe try something drastic by taking it all apart then putting it back together, it might help I've had problems(not computer building ones) that can't be fixed by any diagnostic process but when I started from the beginning it works.
https://linustechtips.com/topic/310618-pc-does-not-post/page/2/#findComment-4222533
The case speaker is the 2 pin speaker connected to the header on the motherboard near where you connect for the power button, reset button etc.
it is really just a buzzer
My motherboard doesn't emit buzzing noises. It emits beeps.
https://linustechtips.com/topic/310618-pc-does-not-post/page/2/#findComment-4223355
Remove the graphics card and try again.
https://linustechtips.com/topic/310618-pc-does-not-post/page/2/#findComment-4223356
ive tried that and also put it in a another pcie slot :/ also pulled all the cables waited for a bit and then put everything back, no go. Funny the fans actually spin for a bit as a start up when the PSU cable is not connected :/ its a 970 strix so fans dont spin until its under load :/
https://linustechtips.com/topic/310618-pc-does-not-post/page/2/#findComment-4223658
