first time build here, PC does not post we have everything that is surely connected, there are even lights on at the mobo and gpu but does not turn on
edit: current specs
i7 5820k
asus x99-a
g.skill ripjaws 4 16gb ddr4
asus strix 970
corsair rm750
samsung evo 840 500gb
seagate 4tb
wd black 2tb
https://linustechtips.com/topic/310618-pc-does-not-post/
Do you have your CPU power connected?
https://linustechtips.com/topic/310618-pc-does-not-post/#findComment-4222007
Is the monitor on? Kind of a silly question but it might not be
CPU: some amd thing Motherboard: its black RAM: its memory thats for sure GPU: r7 260x Case: corsair spec 01 Storage: 1tb of it PSU: 430w, so many watts
Display: its asus Cooling: fans Keyboard: logitech g710+ #browns4lyfe Mouse: its a logitech Sound: its what you hear Operating System: winders
https://linustechtips.com/topic/310618-pc-does-not-post/#findComment-4222013
The OP says the system doesn't power on.
https://linustechtips.com/topic/310618-pc-does-not-post/#findComment-4222020
I have no clue what is that
Your eight pin power connector for the CPU. It might say EPS on it.
https://linustechtips.com/topic/310618-pc-does-not-post/#findComment-4222048
Its a connector in the top left of your motherboard its either a 4pin or 8pin connector that you have to plug a cable from your power supply into
https://linustechtips.com/topic/310618-pc-does-not-post/#findComment-4222049
 yup connected that :/ still no progress
Is the system not posting or not turning on?
https://linustechtips.com/topic/310618-pc-does-not-post/#findComment-4222073
 not turning on at all but there are lights on the mobo and gpu
There might be a switch on the power supply that you have to flick
https://linustechtips.com/topic/310618-pc-does-not-post/#findComment-4222085
speaker case? currently not speakers are connected
yeah everythings flicked on theres even lights on the mobo!
The case speaker is the 2 pin speaker connected to the header on the motherboard near where you connect for the power button, reset button etc.
it is really just a buzzer
:)xD9_9:D:PB|
https://linustechtips.com/topic/310618-pc-does-not-post/#findComment-4222107
there is a small weird small buzzing noise once we disconnect everything then connect it and press the power button but after that nothing at all
That is your POST CODE look it up in your mother board manual with everything connected and it should give you an idea of what is wrong,
:)xD9_9:D:PB|
https://linustechtips.com/topic/310618-pc-does-not-post/#findComment-4222160
ok according to the internet it should work fine then. Are you sure the monitor is plugged in, are you using an adapter etc.
the thing just turned on, dont know why it just decided to but it wont detect the monitor, everything is connected. Also the power button on the case doesnt work we have to manually press on the mobo
https://linustechtips.com/topic/310618-pc-does-not-post/#findComment-4222265
for the power switch problem double check that you have your front panel connectors connected correctly. For the display, have you tried it with any other computer yet? and What output are you using on the GPU and what is the imput you are using for the monitor.
:)xD9_9:D:PB|
https://linustechtips.com/topic/310618-pc-does-not-post/#findComment-4222295
everything seems to be connected, yes I have used it already and currently using a display port no adapters
https://linustechtips.com/topic/310618-pc-does-not-post/#findComment-4222302
