Not enough power(I think)
Go to solution Solved by spwath,
@spwath should i try opening the side panel when the room is cool to chech if temperature is the issue?
sure, see what happens
Heeeey forum monkeys :P ,
I have a problem(again).I have a pc with:an amd fx-6100, a radeon hd7700, an msi mini-itx mobo(its pretty cheap)(don't remember the model), 1 hd, 1 optical and a 550watt psu which I think sucks(its from a local company not a "huge" brand.My pc runs fine and after a couple of minutes of battlefield it drops from 60-70 to the low 20s(tried all kinds of graphics combinations). I have read stuff online but i am not sure
https://linustechtips.com/topic/309891-not-enough-poweri-think/
16gbs.I don't think so because even when new it did it and its not hitting high 90s(celcius)
above 80 is high for that card
https://linustechtips.com/topic/309891-not-enough-poweri-think/#findComment-4212792
https://linustechtips.com/topic/309891-not-enough-poweri-think/#findComment-4212821
