i just bought a asus dc 1g gddr5 7770 and now that i have tried installing it it wont show any display the monitor shows check video cable no matter what output i use that i can anyways i have tried hdmi and dvi-to hdmi adapter my monitor only has vga and hdmi inputs so cant check the display port or dvi i do have a 6pin to molex adapter on it that came from my saphire 7870 in my other pc and i noticed this vid card has a 2 led on the back of the pcb next to the 6pin plug led 1 is lit up green but led 2 is off completely
any thoughts guys?
https://linustechtips.com/topic/30961-issues-installing-a-7770/
The card may be dead.
https://linustechtips.com/topic/30961-issues-installing-a-7770/#findComment-396197
Ask for DOA return since it might be dead :l
Andres "Bluejay" Alejandro Montefusco - The Forums Favorite Bird!!!
Top Clock: 7.889 Ghz Cooled by: Liquid Helium
#ChocolateRAM #OatmealFans #ScratchItHarder #WorstcardBestoverclocker #CrazySexStories #SchnitzelQuest TS3 SERVER
https://linustechtips.com/topic/30961-issues-installing-a-7770/#findComment-396267
gonna try some more with driver sweeper ect but pretty sure it is dead as im not even getting to see my bios with it installed or my psu isnt powering it enough because of only 1 of the leds lighting up next to the 6 pin plug i have a new psu on the way if it works then yay but if not ill know its dead for sure thanks guys
https://linustechtips.com/topic/30961-issues-installing-a-7770/#findComment-396418
If you have a PSU at least at 450 watts you should be fine in that end.
https://linustechtips.com/topic/30961-issues-installing-a-7770/#findComment-396439
its only a 250w i had laying around that i stuck in it till my new one came could that be my problem cause its not even showing me the bios or anything i just figured i couldnt put a load on it till i got the new psu but that it would still work
https://linustechtips.com/topic/30961-issues-installing-a-7770/#findComment-397846
It's not enough power..
Wrong. For boot/desktop in needs like 10-20W.
FX8320 4.2Ghz@1.280v& 4.5 Ghz Turbo@1.312v Thermalright HR-02/w TY-147 140MM+Arctic Cooling 120MMVRM cooled by AMD Stock Cooler Fan 70MM 0-7200 RPM PWM controlled via SpeedfanGigabyte GA990XA-UD3Gigabyte HD 7970 SOC@R9 280X120GiBee Kingston HyperX 3K2TB Toshiba DT01ACA2001TB WD GreenZalman Z11+Enermax 140MM TB Apollish RED+2X Deepcool 120MM and stock fans running @5VSingle Channel Patriot 8GB (1333MHZ)+Dual Channel 4GB&2GB Kingston NANO Gaming(1600MHZ CL9)=14GB 1,600 Jigahurtz 10-10-9-29 CR1@1.28VSirtec High Power 500WASUS Xonar DG, Logitech F510Sony MDR-XD200Edifier X220 + Edifier 3200A4Tech XL-747H 3600dpiA4Tech X7-200MPdecent membrane keyboardPhilips 236V3LSB 23" 1080p@71Hz .
Sorry for my English....
https://linustechtips.com/topic/30961-issues-installing-a-7770/#findComment-397873
Do you have proof of this.. I know my gpu and fans and cpu all run full speed when I boot.. It takes like 5 watts per case fan lol..My 3570k uses 50 watts by it self on idle lmao.
Plus there is not enough amps on the 12 volt rail on a 250 watt psu..
https://linustechtips.com/topic/30961-issues-installing-a-7770/#findComment-397901
Does the board have onboard video? Pull the card out and see if it fires up, if it does, reseat the GPU and have another go, make sure all power plugs in the card are plugged in, a 250w PSU may not have the 6/8pins required. If it doesn't... PSU might be drawing too much on start up...
https://linustechtips.com/topic/30961-issues-installing-a-7770/#findComment-398438
yep hopefully its my psu cause i already bought a replacement that will be here in a few days and will save me the shipping of the rma of the vid card
and re-seating isnt working iv even pulled my system from the case and box mounted it too make sure my case wasnt the problem
also yes everything goes fine without the car installed and with it (except no display of course) on-board vid and my little amd 6570 and ati 4350 work fine but both of those dont require additional power from the psu
https://linustechtips.com/topic/30961-issues-installing-a-7770/#findComment-398623
well got my new psu today and no dice but it wasnt the real problem the problem is my mobo is pcie x16 1.1 and its a 3.0 card and ii was able to foind some one to let me test it in their rig and it works just fine
PCI-E 3.0 cards are backwards compatible with PCI-E 1.0 and 2.0. Are you sure the slots are working properly on your board?
https://linustechtips.com/topic/30961-issues-installing-a-7770/#findComment-406064
yes i am i am still using my old 6570 in it witch is pci e 2.1 while i wait on my new mobo and idk but asus who made both the vid card and my mobo said 3.0 will not work on 1.0 it could just be their own built in limitation but im not sure all i know is i did validate what they told me when i tested it in 3 boards mine with 1.0 and 2 of a friends 1 with 2.0 and 1 with 3.0 and only time the card didnt work was on 1.0 also i think it goes card-wise 1 in 1  , 2 in 2 or 1   , 3 in 3 or 2 but slot-wise its fully back compatible is what they explained to me
https://linustechtips.com/topic/30961-issues-installing-a-7770/#findComment-408147
Okay.
https://linustechtips.com/topic/30961-issues-installing-a-7770/#findComment-408152
If it doesn't work, then it doesn't work.
https://linustechtips.com/topic/30961-issues-installing-a-7770/#findComment-408456
