I just bought a 4690k and i have a Seidon 120v CLC cooler. Im running a stress test to see if its stable out of the box and its at 74 degrees celcious at 3.7 Ghz on 1.025 V. Why is it so hot? I had a G3258 that was overclocked to 4.2 Ghz at i think like 1.23 V and ran at 70 degrees celcious on full load in prime 95. Any reason its so hot? Also i just looked away and it went back down to low 60's and as i watch it, it goes back up to high 60's. Then back down. So its flucuating alot. Why?
https://linustechtips.com/topic/309510-i5-4690k-overheating/
Maybe the thermal paste, maybe it's hot in your room, maybe the tim inside the ihs is really bad....
rig: i7 4770k @4.1Ghz (delidded), Corsair Vengeance 8GB 1600Mhz, ROG Maximus VI Hero, Noctua NH-D14, EVGA GTX980SC, Samsung 850 EVO 500GB, Corsair SF600, self-built wooden Case, CoolerMaster QuickFire TK, Logitech G502, Blue Yeti, BenQ GW2760HS
https://linustechtips.com/topic/309510-i5-4690k-overheating/#findComment-4207051
Reseat the cooler and reapply thermal paste. if that doesn't do it, like @EMENCII said, could be hot in toyr room of the tim is bad.
Am I the only one around here who really doesn't like pcpartpicker?
I also like Ubisoft and Origin/EA
Guess I'm just odd that way.
HATER OF MAIL IN REBATES!
https://linustechtips.com/topic/309510-i5-4690k-overheating/#findComment-4207076
You should not use Prime 95 with Haswell chips, it pushes them a lot further than they will ever go and is not an accurate representation. I suggest to download the AIDA 64 demo and use that for stability/temp tests.
widget.png?style=banner2
PC: 9800X3D, 96GB Trident Z5 6200 CL28, 5090 FE, 3.84TB CM7
NAS: Xeon W-2195, 256GB ECC, 180TB Storage, 1660 Ti, TrueNAS Scale
https://linustechtips.com/topic/309510-i5-4690k-overheating/#findComment-4207121
Alright, ill try all that. Thanks, i appreciate it.
https://linustechtips.com/topic/309510-i5-4690k-overheating/#findComment-4207216
What tool are you using to stress test it? Use aida64 because Prime95 has a problem with overvolting haswell cpus, and you should never use it.
I7 4790K @4.5 Ghz 1.294V
VALIDATION, MSI Z97 Gaming 7, 24GB DDR3 1600, Asus Strix 1070 8GB OC@ 2.2Ghz, Corsair graphite series 760T (Black), Cooler master V850, NH-D15 w/LNA ,1TB Samsung 850 Evo,  480GB Sandisk Ultra II SSD, 3TB Seagate Barracuda x 3, 1 TB WD Passport (Backup drive), 2 TB WD Passport (Backup Drive 2),  Windows 10 Pro x64 (uhg), Logitech G900 Chaos (Main), Steelseries Rival (FADE) (Courtesy of Edzel Yago, Thanks Ed), Steelsieres Rival 300 Hyperbeast Special Edition, Coolermaster Quickfire TKL (MX Blue), Razer Blackwidow Tournament edition (Greens).  Audio: Sennheiser HD598 SE, Edifier S1000DB, AudioEngine D1 DAC; Yamaha MG06X Mixer & AudioTechnica AT2020.
Phones; Daily drivers: Nexus 6P 64GB/iPhone 6 (Music), Apple Watch, Apple AirPods.
Laptop: 2015 Macbook Pro 13, 8GB of RAM, 2.7Ghz i5, 240GB Apple SSD.
Plex Server: i7 3770, Gigabyte Board, 16GB DDR3 1600, Asus Strix GTX 1050ti 4GB, 120GB SSD Boot Drive, 8 x 3TB Seagate Barracuda, Rosewill RSV-R4000 With 2 Rosewill Hot Swap 4x Backplane Bays, 1050 Watt Corsair HX Series PSU,Hyper T2, Windows 10 Pro
I also do Youtube, check me out!
https://linustechtips.com/topic/309510-i5-4690k-overheating/#findComment-4207389
