Best tool(s) for window mod.
Tasuma
I am thinking about putting a window on my 200r. And was looking around on forums, vids, and other sites. What tools would I need? I was reading a dremel and jig saw. Could I just use the dremel? If so what discs? Much love all!!!
01101100 01110110 01101100 00100000 00110101 00100000 01101101 01100001 01100111 01101001 01101011 01100001 01110010 01110000
A dreamer with a circular blade can make it, though you will have trouble with the any curved cuts
Planning on trying StarCitizen (Highly recommended)? STAR-NR5P-CJFR is my referal link
A Dremel is good, you'll want to use reinforced metal cutting discs, make sure to map out your cut on some masking tape and cut away from the line and to use a file afterwards to file it to the line and make it perfectly straight afterwards.
That is what I was gonna do. What disk would you use?
Last time I did cuts on my case I used theses, but not the Dremel brand ones, it doesn't really matter as long as you can get theses kinds for a decent price.
http://www.dremel.com/en-ca/Accessories/Pages/ProductDetail.aspx?pid=426
This should help:
-Dremel
-Jigsaw tool
Motherboard:: Asus Maxiumus ROG Crosshair VII AM4     Ram:: G.SKILL TridentZ RGB Series 16GB (2 x 8GB)     SSD:: Intel 730 series 240Gb SSD
 GPU:: ASUS GTX 1080 8GB ROG Strix     CPU:: AMD Ryzen 7 2700x @3.70GHz   COOLING:: NZXT Kraken x72 AiO, 3x Thermaltake Riing Plus
Jigsaw works.
