You might want to begin looking at upgrading your entire rig. You are fine now but the question is for upcoming games. Bf4 is beginning to get old.
CM Storm Switch Tester MOD (In-Progress) - http://linustechtips.com/main/topic/409147-cm-storm-switch-tester-macro-mod/
       Ammo Can Speaker 02 (Completed) - http://linustechtips.com/main/topic/283826-ammo-can-speakers-02/       A/B Switch V 0.5 (Completed) - http://linustechtips.com/main/topic/362417-ab-switch-v0
     Build 01 - The Life of a Prodigy -  http://linustechtips.com/main/topic/13103-build-01-the-life-of-a-prodigy/             Build 02 - Silent Server 3000 - http://linustechtips.com/main/topic/116670-build-02-silent-server-3000/
https://linustechtips.com/topic/308537-how-to-overclock-cpu/#findComment-4193379
sure bro thx a lot
when i get the money i will upgrade but im fine till bf 5 comes :)
https://linustechtips.com/topic/308537-how-to-overclock-cpu/#findComment-4193394
sure bro thx a lot
You can buy it now and play bf4 without problems , and yeah enable mantle it will help.
I played bf with a phenom II at 60 fps easily.
https://linustechtips.com/topic/308537-how-to-overclock-cpu/#findComment-4193400
