I have a corsair h90 that I had in amd configuration. Now I want to put it into Intel configuration, the problem is: there are screws I cannot figure out how to remove so that I can get to the locking mechanisms for the lga 1155 configuration. I hope this doesn't sound like gibberish to everyone.....
https://linustechtips.com/topic/308286-problems-with-screws-on-h90/
They screws and the plastic around it just clips into the metal ring it should just unclip to take it off.
http://www.tweaktown.com/reviews/5231/corsair-hydro-series-h90-aio-cpu-cooler-review/index7.html
