Hi guys,
I am hoping to in a couple of months swap my AMD MB and CPU for intel (4790k, asrock z97 extreme 6) and i have heard this can cause problems for booting into windows? Is the version of windows i installed linked to my MB? Should i just be able to do a straight swap and just fire it up into windows all fine?
'FrostNova' https://uk.pcpartpicker.com/user/Samsterstorm/saved/WtBWGX :
CPU: Intel 4790k | MB: Asrock Z97 Extreme6 | GPU: Gigabyte GTX 970 G1 Gaming (+200, +250) | CASE: NZXT H440 (Black & Blue) | COOLER: Full EK 240mm CPU Loop | RAM: 16GB Hyper-X Fury (4x4GB @2133mhz) | STORAGE: Seagate Barracuda 1TB & Hyperx 120gb SSD | PSU: Corsair RM650 | SCREEN: Benq G2750 | LIGHTING: Deepcool RGB LED Kit | KEYBOARD: CM Devastator | MOUSE: Logitech G502 | HEADSET: Hyperx Clouds White
Depends, did you use oem version of windows or retail?
I used dell install disk for vista then upgraded it with a dell disk to windows 7?
