(a)
P(x>=a) == 1 - P(x<a)
=> 1 - P(x<a) = 0.01
=> P(x<a) = 0.99
Look up the value that gives 0.99 in the normal distribution table.
(a-38)/6 = [value off table]
Something like that if I remember correctly. My memory is too shaky to be sure anymore or be bothered to try the others. This is also working off the assumption that the task isn't to get an estimate using a different distribution.
https://linustechtips.com/topic/307930-help-me-please/#findComment-4184830
(a)
=> P(x<a) = 0.99
Thanks for solving! but now my problem is C)  D:
i5 2400 | ASUS RTX 4090 TUF OC | Seasonic 1200W Prime Gold | WD Green 120gb | WD Blue 1tb | some ram | a random case
https://linustechtips.com/topic/307930-help-me-please/#findComment-4185105
