just get a torx screwdriver set.
https://linustechtips.com/topic/307506-help/#findComment-4178240
I'm gonna ask a stupid question.... What is that
That's an incredibly stupid question (:
Torx (pronounced "torks"), developed in 1967 by Camcar Textron, is the trademark for a type of screw head characterized by a 6-point star-shaped pattern.
Sig under construction.
https://linustechtips.com/topic/307506-help/#findComment-4178534
It's not a stupid question.   However, I have a feeling you'll want a security torx bit.  The security screw has a raised center to make it slightly more difficult to open. Years ago, I managed to open mine with a small flat-head screw driver, but it's hard to completely describe how to position it.
Check out this for the original design
This one for the slim revision.
And this one for the last version
https://linustechtips.com/topic/307506-help/#findComment-4180565
And this one for the last version.
This will help me, but the problem is that in the middle of the torx screw there is a nub that wont let me unscrew it
https://linustechtips.com/topic/307506-help/#findComment-4181708
Ya that's what I was saying in my previous most.  I was able to turn the security screw on mine by using a small screwdriver in the gap as shown in the picture.  If you have one small enough, it's pretty easy.  There's enough leverage.
https://linustechtips.com/topic/307506-help/#findComment-4181808
If you want a proper screw driver for this you need the "tamper proof" ones link these http://www.amazon.com/Silverhill-Point-Tamper-Proof-Piece/dp/B002P4YCGM/ref=pd_sim_hi_4?ie=UTF8&refRID=1ZGR5CHRE33T74RNPXA4
Some times refered to as T* as opposed to normal Torx which are T
https://linustechtips.com/topic/307506-help/#findComment-4183615
That one won't work (wrong shape), but this one will.
http://www.amazon.com/gp/aw/d/B0002SPLQ8/ref=mp_s_a_1_cc_2?qid=1423572051&sr=1-2-catcorrπ=AC_SX110_SY165_QL70&keywords=Torx+security+bit
https://linustechtips.com/topic/307506-help/#findComment-4183733
Okay thanks this helps, If i cant find something small enough to unscrew it with i will get the special screw set that you posted.
https://linustechtips.com/topic/307506-help/#findComment-4187098
Well it is a bit dumb, considering he could have Googled it. :0/
;0P
I just found something that fit. I think I just used a flat-head that fit.
Be really careful with the ribbon cable latches, they're really delicate and if they break (or detach, and you can't get them back on) then it's pretty much over for the PS3.
"I try to put good out into the world...that way I can believe it's out there." --CKN                  “How people treat you is their karma; how you react is yours.” --Wayne Dyer
[Needs Updating] My PC: i5-10600K @TBD / 32GB DDR4 @4000MHz / Z490 AORUS Elite AC / Titan RTX / Samsung 1TB 960 Evo / EVGA SuperNova 850 T2
https://linustechtips.com/topic/307506-help/#findComment-4189747
Nearly every question asked on any forum can be found by Google'ing.    And nearly every Google search has a forum reply in the top 5 results.
That inherently makes asking questions in a forum a very good idea.  Even the "dumb" ones.
https://linustechtips.com/topic/307506-help/#findComment-4189901
Dude, I was joking. :0P
https://linustechtips.com/topic/307506-help/#findComment-4189949
I can be oblivious sometimes.   :mellow:
That's okay. Apologies if it looked like hostility. Maybe I should edit it (you can't always tell what people mean in text) :0/
https://linustechtips.com/topic/307506-help/#findComment-4190123
Those would be torx security bits. They are a pain in the ass. You will have to buy a specific driver for this but once you own one thy are nice to have around for other things.
Windows 10 likes to spy on you. Protect your Data! Run GNU/Linux!
That One Privacy Guy's VPN Comparison Chart.
|ARCH LINUX| |CPU i5 4690k @ 4.7GHz| |GPU: Asus Strix 390x| |Mobo: Asus Sabertooth Z97 Mk 2| |RAM: Corsair Veangence Pro 16gb (2x8gb) @2133mhz| |CPU Cooler: Corsair H100i| |PSU: 750w EVGA Supernova 80+ Gold| |Case: Phanteks Enthoo Evolv ATX(Silver)| |K/B: Pok3r w/ Cherry MX Blues|
|Samsung 250GB 840 EVO: Arch Linux installation.| |Seagate Barracuda 2TB: Mostly Games and stuff related to that. Music and most Media as well.| |Seagate NAS 4TB: Anime and Anime Art-Whoring.| |Seagate 1TB 2.5" SSHD: Arch install on my Thinkpad X220.| |Samsung OEM Lenovo SSD: Windows 8.1 cause I need to play JRPGs some how.|
|Cans: Sennheiser HD 558(Modded)| |Earbuds: Shure SE215| I'm working on expanding this.
https://linustechtips.com/topic/307506-help/#findComment-4190669
