Hello , since my jbl 88i broke down after a 3 months use ( DO NOT BUY THEM )
I am looking to buy a new pair
I was thinking mayflower electronic their v1 and get the headband so it can be confortable
Whats other headphones do you suggest me at that price point
Good sound quality and good build quality
https://linustechtips.com/topic/307388-headphones-questions/
https://linustechtips.com/topic/307388-headphones-questions/#findComment-4176625
It's hard to wrong with HD558 at $90. I'd take used K612 ($130) over HD558 but most likely you'll need to spend additional money on amp
why to get an amp?
Here check this headphone 150$ which may get you with some idea.
Are the sony ones good?
Any particular reason you're interested in the V1 over other headphones?
becuse they are like little tanks and they are great
https://linustechtips.com/topic/307388-headphones-questions/#findComment-4182079
why to get an amp?
Simply because the AKG is inefficient, it's only 120ohm but it's very insensitive (means low dB of sound reproduction per watt)
MDR7506 and M40x are good choices, I'd recommend M40x over MDR7506 if you're going to use it for portable as it has removable cable and foldable
https://linustechtips.com/topic/307388-headphones-questions/#findComment-4182632
I ran the 612 off my 2012 tablet with great effect :/
https://linustechtips.com/topic/307388-headphones-questions/#findComment-4182712
budget around 150 $ and I listen to different covers and gaming ( but I do not need gaming headphones )
Technically, there is no such thing as 'gaming headphones'. Audio is audio, and good audio is well...good. Few members here have been using something like HD800, LCD-2, etc for gaming...
https://linustechtips.com/topic/307388-headphones-questions/#findComment-4182975
Hope you were able to catch 'em afterwards.
so what you guys think , I like to listen to music and play online games
https://linustechtips.com/topic/307388-headphones-questions/#findComment-4184431
That was the goal. Point is I bought the DT 880 instead of the K612; not saying it's the best because that would be dumb.
So I ended up between those:
1) Audio Technica M50x black
2) Berrydynamics DT 990
3) Mayflower electronics V1
Please I need a quick answer
https://linustechtips.com/topic/307388-headphones-questions/#findComment-4193599
