Hi, I have a problem with my PC, my WI-FI connection cuts off every time and a windows message pops up saying that another PC has the same IP adress as mine and the connection is interrupting. My PC stops receiving WI-FI connection every time, How can I fix this ?
Can some one help me please ?
P.S: Sorry for my english :S
https://linustechtips.com/topic/306880-problem-with-ip-adress/
open CMD
type ipconfig /release
type ipconfing /renew
https://linustechtips.com/topic/306880-problem-with-ip-adress/#findComment-4169342
This.
Also try changing your device's MAC address.
What? that's not possible.
Hi, I did it. But what is it supposed to do ?
the commands above send a request to your router (that runs the DHCP service) that its ditching its current IP given to it by the router (seems you have an address conflict this should solve that issue) and then the /renew sends out another request for a new IP address from the router.
Did it solve your problem?
Quack 🦆
https://linustechtips.com/topic/306880-problem-with-ip-adress/#findComment-4169445
I just did the ''/renew'' thing, for now all is ok but I dont know if it changed my IP adress.
https://linustechtips.com/topic/306880-problem-with-ip-adress/#findComment-4169485
