Hello,
I am planning on building a mini itx rig thats completely watercooled (Ram,CPU,GPU,Hardline). Since theres only one PCI slot, I need one card that will exceed the standard, without costing me a fortune. This card will be running three monitors so It needs to be able to handle that. Also, I need to be able to buy a waterblock for it, most likely EK. I am also willing to overclock the card so thats a factor. Also, I would buy a used card as well because I have done that before so any discontinued cards are on my list as well. It depends on the card but I am willing to spend around $400 to $500. Any suggestions on cards.
As a side note, can I use dual GPU cards like the 295x2 or the 690 on a mini itx board. If so Ill skip this question and buy one of those two cards.
Thanks,
~Arctic
Is that a computer or a jet engine? Why not both?
https://linustechtips.com/topic/306777-water-cooled-single-gpu/
You could use a dual gpu on a mini-itx case but it all depends on you case
Cases like the 250D and pridogy won't support such a large card.
Maybe the 250D but not sure
9590|EK-Copper|Sabertooth 990FXR2.0|16GB RIPJAWS Z|Dual MSI Gaming 290|Corsiar AX1200i|Corsair 760T|3TB Seagate+Dual 120GB Samsung 850EVO in Raid 0
LTT'S Official Radeon Master Race Club Founder-Predicts TitanX2 (Prediction Date: 3-30-15)
XFX Needs To Make A 3 Fan Cooler
https://linustechtips.com/topic/306777-water-cooled-single-gpu/#findComment-4167819
How many slots do you have ??? like in the case it self not the motherboard.
  ﷲ   Muslim Member  ﷲ
KennyS and ScreaM are my role models in CSGO.
CPU: i3-4130 Motherboard: Gigabyte H81M-S2PH RAM: 8GB Kingston hyperx fury HDD: WD caviar black 1TB GPU: MSI 750TI twin frozr II Case: Aerocool Xpredator X3 PSU: Corsair RM650
https://linustechtips.com/topic/306777-water-cooled-single-gpu/#findComment-4167820
AFAIK There is only 1 16x PCI slot on mini itx    NVM found others
CPU: Xeon 1230v3 - GPU: GTX 770  - SSD: 120GB 840 Evo - HDD: WD Blue 1TB - RAM: Ballistix 8GB - Case: CM N400 - PSU: CX 600M - Cooling: Cooler Master 212 Evo
Update Plans: Mini ITX this bitch
https://linustechtips.com/topic/306777-water-cooled-single-gpu/#findComment-4167823
@ArcticfoxHQ
Assuming you have enough space for the tubing and enough rad+fan clearance then the R9 295x2 can be used
RIG: I7-4790k @ 4.5GHz | MSI Z97S SLI Plus | 12GB Geil Dragon RAM 1333MHz | Gigabyte G1 Gaming GTX 970 (1550MHz core/7800MHz memory) @ +18mV(Maxed out at 1650/7800 so far) | Corsair RM750 | Samsung 840 EVO 120GB, 1TB Seagate Barracuda | Fractal Design Arc Midi R2 (Closed) | Sound Blaster Z        Getting: Noctua NH-D15 | Possible 250GB Samsung 850 Evo        Need a console killer that actually shits on every console? Here you go (No MIR/Promo)
This is why you should not get an FX CPU for ANY scenario other than rendering on a budget http://linustechtips.com/main/topic/286142-fx-8350-r9-290-psu-requirements/?p=3892901 http://linustechtips.com/main/topic/266481-an-issue-with-people-bashing-the-fx-cpus/?p=3620861
https://linustechtips.com/topic/306777-water-cooled-single-gpu/#findComment-4167833
want to do mini itx water cooling? go bitfenix prodigy. it can fit up to 12.5 inch gpus and has a lot of mounting for radiators. they are 240 mm at the front, 240 mm at the top, and 120 mm at the back
Rigs I've Built
The Striker i5 4590 @ 3.7 ||  MSI GTX 980 Armor X2 || Corsair RMX 750 || Team Elite Plus 8 GB || Define S || MSI Z97S SLI Krait
The Office PC i3 4160 @ 3.6 || Intel 4600 || EVGA 500B || G.Skill 8 GB || Cooler Master N200 || ASRock H97M Pro4
The Friend PC G3258 @ 4.3 || Sapphire R9 280X Tri-X || EVGA 600B || 8 GB Dell Ram || Cooler Master N200 || ASRock H97M- iTX/ac
The Mom Gaming PC A10-7890K @ 4.4 || iGPU + ASUS R7 250 ||  8 GB Klevv DDR3-2800 Mhz
https://linustechtips.com/topic/306777-water-cooled-single-gpu/#findComment-4167866
I found this while looking around. Fairly decent deal for a 780 with a water block if you ask me.
http://www.ebay.com/itm/Zotac-GTX-780-with-EKWB-waterblock-/231469522014?pt=LH_DefaultDomain_0&hash=item35e4a89c5e
Or else you can look into getting either a R9 290x/GTX 970 and buy a water block separate.
https://linustechtips.com/topic/306777-water-cooled-single-gpu/#findComment-4167891
@ArcticfoxHQ
I'm doing a scratch build case. I have as much room or slots as i want but i just want the form factor to remain small.
https://linustechtips.com/topic/306777-water-cooled-single-gpu/#findComment-4168034
So wait I can use the card if I have enough space?
The main issue with the R9 295x2 is the length of the card. Almost 31cm, or just over 12 inches.
There are blocks for the card (if you don't want to use the cooling solution that comes with the card).
https://linustechtips.com/topic/306777-water-cooled-single-gpu/#findComment-4168064
I can afford the card and the block. I also have the space. But can my mother board properly use the card?
https://linustechtips.com/topic/306777-water-cooled-single-gpu/#findComment-4168114
