Recommended graphics card for Core 2 Quad Q6600 CPU (@ 3GHz) and Asus P5KC motherboard (PCI-E 1.0)
I'm looking for the best graphics card for my old PC such that it won't be bottle-necked by the following components, which i do not intend to upgrade anymore:
- CPU: Intel Core 2 Quad Q6600 overclocked at 3 GHz
- Motherboard: Asus P5KC - looks like it supports only PCI-E 1.0; also, it supports DDR2 RAM only
- Case: Antec 302 - it's a mid-tower case, so it won't fit comfortably very long cards
I will probably upgrade though the current amount of RAM from 4 GB to 8 GB and the power supply if needed.
As you can imagine, i'm not necessarily looking for last-gen 4K GPUs, but instead the best GPU whose maximum performance won't be unattainable due to bottle-necking of the rest of the components. Right now i don't have any budget limitations planned for this.
Your suggestions are greatly appreciated.
Anything suggested here will work fine. PCI-E revision specs don't change the physical socket like the old AGP ones did, so don't worry about that. It won't bottleneck it either.
750 ti is probably the best solution for you or an R9 270, that Q6600 is still a good chip even after all these years but pairing it with a GTX 970 might be pushing the envelope.
