ROCCAT RYOS MK Pro?
Solved by Ostwind,
Is the wrist rest comfortable?
You should quote someone so they know you replied to their post, you should also follow any threads you make so that you get notified when someone posts on your thread. That being said the wrist rest was as comfortable as any other board I have used. I had a bit of difficulty adjusting as the Ryos was five or six times thicker than my old keyboard and almost twice as thick as a normal keyboard, keep that in mind if you plan on buying.
