What cable does this printer use?
Go to solution Solved by Aniallation,
I have a Brother printer, I'm not sure what type but it mentions "LC71" and "LC75"
Pretty sure it's just a standard USB A-B cable
Its USB Type B
CPU: some amd thing Motherboard: its black RAM: its memory thats for sure GPU: r7 260x Case: corsair spec 01 Storage: 1tb of it PSU: 430w, so many watts
Display: its asus Cooling: fans Keyboard: logitech g710+ #browns4lyfe Mouse: its a logitech Sound: its what you hear Operating System: winders
It is one of the types of USB conectors, specifically the type B which Linus describes in the beginning of this techquickie video.
It is basically an upstream USB conector designed for devices that are being controlled and is still the ubiquitous conector for devices such as printers, meaning they are cheap and readily available.
