ok so i got home and was just about to start a hackingtosh attempt so i go in to bios and set it all to the diffualt settings and procedded to restart once turnt on it wouldnt post and the led next to vga card stays on as to signal problem im using a sabbertooth 990fx r2.0 any help ???
I did a thing once and it was awsome: https://soundcloud.com/jamese666/junkhead-cover-with-vocals
https://linustechtips.com/topic/30566-pc-wont-post/
Try resetting the BIOS through removal of the CMOS battery for about 10 seconds.
https://linustechtips.com/topic/30566-pc-wont-post/#findComment-391407
Reseat the ram, take it out and push it back in. It probably is not down all of the way. Sent from my HTC One using Tapatalk 4 Beta
the pc been working fine for 2 months so that def isnt the problem
https://linustechtips.com/topic/30566-pc-wont-post/#findComment-391536
Maybe you bumped the computer? Its a common problem... Or your CPU got knocked loose ? Just reseat everything as if you were building a new computer.
https://linustechtips.com/topic/30566-pc-wont-post/#findComment-391707
Maybe you bumped the computer? Its a common problem... Or your CPU got knocked loose ? Just reseat everything as if you were building a new computer. Sent from my HTC One using Tapatalk 4 Beta
i have no thermal paste so taking out the cpu would be a pain
https://linustechtips.com/topic/30566-pc-wont-post/#findComment-391874
More than likely your board as failed.... too verify
disconnect every thing from the motherboard, take out and reseat the CPU, having no thermal paste doesn't matter for now.
Install one stick of RAM...If it posts Install a 2nd stick of RAM...and continue adding components until it no longer posts, and then you will have the cause of your problem.
If it does not post with either stick of ram in (assuming you have multiple) its either the board (most likely) or the CPU that has failed...
Good Luck.
----Ryzen R9 5900X----X570 Aorus elite----Vetroo V5----240GB Kingston HyperX 3k----Samsung 250GB EVO840----512GB Kingston Nvme----3TB Seagate----4TB Western Digital Green----8TB Seagate----32GB Patriot Viper 4 3200Mhz CL 16 ----Power Color Red dragon 5700XT----Fractal Design R4 Black Pearl ----Corsair RM850w----
https://linustechtips.com/topic/30566-pc-wont-post/#findComment-392179
This guy is asking for help, but is too lazy to take our advice...SMH Sent from my HTC One using Tapatalk 4 Beta
right just to let you know i done what you said and quess what it dint work. so before you got jummping to conclusions why dont you ask if i have done it
https://linustechtips.com/topic/30566-pc-wont-post/#findComment-392457
Good Luck.
hey i have resited the cpu and did what you said and still dosnt work it the vga led stay lit when consulting with my motherboard manual when the led stays lit i mean theres a problem but when i put both gpus in my fathers system they work fine i also tryed flashing the bios in hopes it was the bio playing up but it would flash  (using asus's bios flash back thingy)
https://linustechtips.com/topic/30566-pc-wont-post/#findComment-392473
sounding like either board or CPU is dead.
https://linustechtips.com/topic/30566-pc-wont-post/#findComment-392677
If my desktop doesn't post, I unplug it from the wall and press the power button to 'drain' all the power! Then plug it back in and try :)
yes thats called an ATX reset, also worth a try...
https://linustechtips.com/topic/30566-pc-wont-post/#findComment-392762
ahhh thanks guys ill give it a go and let you know how it go's :) yhave to put ram in and plug in cpu fan first so ill give it ten mins before i do it
Edit: no luck at all :( o well just gonna have to wait till monday
https://linustechtips.com/topic/30566-pc-wont-post/#findComment-392845
im actually sorta having the same issue, my bios derped up and now my pc boots fine, no beeps or error codes but no image on the screen, resetting cmos doesn't help me. if you find a solution tell me, it may help me out :D
Case: NZXT Phantom PSU: EVGA G2 650w Motherboard: Asus Z97-Pro (Wifi-AC) CPU: 4690K @4.2ghz/1.2V Cooler: Noctua NH-D15 Ram: Kingston HyperX FURY 16GB 1866mhz GPU: Gigabyte G1 GTX970 Storage: (2x) WD Caviar Blue 1TB, Crucial MX100 256GB SSD, Samsung 840 SSD Wifi: TP Link WDN4800
Donkeys are love, Donkeys are life.                    "No answer means no problem!" - Luke 2015
https://linustechtips.com/topic/30566-pc-wont-post/#findComment-393237
dude do what i did at first and try your gpu/'s ram works on a diffrent pc that kinda helps on what the problem is that how i knew it was my mobo playing up
https://linustechtips.com/topic/30566-pc-wont-post/#findComment-394280
sounds like a mobo fault
just to clarify
1. checked cpu fitting - didnt work - have you got another board that will take that cpu if so you could try it in that and see what happens
2. checked ram fitting - didnt work - again try in another mobo
3. reset cmos - didnt work
4. reflash bios - didnt work
5. have you tried just a basic boot (by that i mean just keyboard vga and mouse, remove everything else, no hard drive, cd, usb drives and if got onboard video remove any add-in video cards etc)
6. do you get any bios error beeps - quickest way of finds mobo faults 3 beeps normally means faulty ram
7. did you clean shut down your pc last time
8. what was you doing last time you used your pc.
9. what was the last software you installed
10. have you overclocked your pc in anyway
11. how old is your pc
12. have you knocked/dropped your pc recently
some of these questions might seem irreverent but they will all help us to help you. the more info you can give us the faster we can find a solution for you.
p.s i have a hackintosh as well running it on my msi cr700 laptop cpu - intel celeron t3300 dual core 2ghz ram- 4gb ddr2 666mhz gpu- nvidia geforce 8200m g
running os x lion and runs well i can even play minecraft ..... at 20fps lol
answer these and we see if we can help you further
  • CPU
  • Motherboard
  • RAM
  • GPU
  • Case
  • Storage
  • PSU
  • Display(s)
  • Cooling
  • Keyboard
  • Mouse
  • Sound
  • Operating System
https://linustechtips.com/topic/30566-pc-wont-post/#findComment-394351
just to clarify
no other board in house that'll run my  8320 plus my motherboard come back saying he cpu is fine(onboard led)
rams fine had put it in othe pc worked plus mother board led came back ok
have done so but dint work
dint work
yes dint work
case do'snt have built in speaker
nope accidently turn it off by the mains
gaming
asus gpu tweaker
have not had chance to do so
couple of months
no
hope this help dignosing :)
https://linustechtips.com/topic/30566-pc-wont-post/#findComment-394518
