I see a common "fact" that is reported about Dying Light using 3.5GBs of VRAM getting thrown around all over the place, but the sources for these claims all seem to be from tests or anecdotal evidence while using 4GB GPUs.
Are there are reliable VRAM usage benchmarks out there for Dying Light using smaller and larger cards at the same settings/resolutions for comparison? I've seen some claim that the game was using over 4.5GBs while running a 6GB card, and others (including myself) showing much less when running the game on smaller cards.
In my own personal experience, running an R9 270X 2GB, with shadows, foliage, and textures set to high, I only saw around 1700-1800MBs of VRAM usage when monitoring with MSI Afterburner. The biggest inconsistency with my result, however, is that I do not have a 1080p monitor. The game is played at 1600x900. I'm not sure if the increase in resolution would also increase the VRAM usage by nearly 100%, however.
It's something worth testing, in my opinion. Though I lack the means to do so.
"A picture is starting to form here... I wonder if it's accurate? Some pieces don't quite seem to fit. Or maybe I just don't like the way it looks."
https://linustechtips.com/topic/305607-dying-light-and-vram/
I was reaching my 3GB cap on whatever the high settings are and half render distance, with a resolution of 2560x1440. I could see it going beyond 3GB easily at that resolution.
If I turn shadows down from very high to high vram usage drops by like 250MB
Corsair 400C- Intel i7 6700- Gigabyte Gaming 6- GTX 1080 Founders Ed. - Intel 530 120GB + 2xWD 1TB + Adata 610 256GB- 16GB 2400MHz G.Skill- Evga G2 650 PSU- Corsair H110- ASUS PB278Q- Dell u2412m- Logitech G710+ - Logitech g700 - Sennheiser PC350 SE/598se
Is it just me or is Grammar slowly becoming extinct on LTT?
https://linustechtips.com/topic/305607-dying-light-and-vram/#findComment-4154320
I have max settings, 1080p, without motion blur and 50% on view distance and was capped at around 3.5gb. the game would stutter if I tried entering a cut scene to fast. Setting view distance to minimum solved the issue with vram at about 3gb now
Case: NZXT Phantom PSU: EVGA G2 650w Motherboard: Asus Z97-Pro (Wifi-AC) CPU: 4690K @4.2ghz/1.2V Cooler: Noctua NH-D15 Ram: Kingston HyperX FURY 16GB 1866mhz GPU: Gigabyte G1 GTX970 Storage: (2x) WD Caviar Blue 1TB, Crucial MX100 256GB SSD, Samsung 840 SSD Wifi: TP Link WDN4800
Donkeys are love, Donkeys are life.                    "No answer means no problem!" - Luke 2015
https://linustechtips.com/topic/305607-dying-light-and-vram/#findComment-4158009
Running a gtx 980 with 4gb
I get around 1878mb usage on everything but textures, field of view 94 and half view distance no aa
And right at 4 gigs with aa and high textures..
I don't get any stuttering except when my normal ram gets maxed out at 8gb only when I leave LTT running in the background though.
I don't know for sure but it seems like there is some kind of overflow when you run out of vram.
Maybe optimized for using system memory better then most games, all my other games it's impossible not to notice when you cap out vram.
if this helps there u go all my tests were at 1080p
https://linustechtips.com/topic/305607-dying-light-and-vram/#findComment-4165399
Game will use as much as it can and optimise itself if you don't have enough. There isn't just a blanket 3.5GB Requirement.
i7 6700K - ASUS Maximus VIII Ranger - Corsair H110i GT CPU Cooler - EVGA GTX 980 Ti ACX2.0+ SC+ - 16GB Corsair Vengeance LPX 3000MHz - Samsung 850 EVO 500GB - AX760i - Corsair 450D - XB270HU G-Sync Monitor
i7 3770K - H110 Corsair CPU Cooler - ASUS P8Z77 V-PRO - GTX 980 Reference - 16GB HyperX Beast 1600MHz - Intel 240GB SSD - HX750i - Corsair 750D - XB270HU G-Sync Monitor
https://linustechtips.com/topic/305607-dying-light-and-vram/#findComment-4165658
I seem to use 3.7GB at 1440P on my 980'S
My bro mentioned the R0R9 290 hitting around 3.4-3.5GB at 1080P.
i7 5930k . 16GB Corsair Vengeance LPX 2666 DDR4 . Gigabyte GA-X99-Gaming G1-WIFI . Zotac GeForce GTX 980 AMP! 4GB SLi . Crucial M550 1TB SSD . LG BD . Fractal Design Define R2 Black Pearl . SuperFlower Leadex Gold 750w . BenQ GW2765HT 2560x1440 . CM Storm QF TK MX Blue . SteelSeries Rival
i5 2500k/ EVGA Z68SLi/ FX 8320/ Phenom II B55 x4/ MSI 790FX-GD70/ G.skill Ripjaws X 1600 8GB kit/ Geil Black Dragon 1600 4GB kit/ Sapphire Ref R9 290/ XFX DD GHOST 7770
https://linustechtips.com/topic/305607-dying-light-and-vram/#findComment-4166523
