Both will be fed properly, but make sure they don't exceed 1A (refer to motor hub sticker).
https://linustechtips.com/topic/305047-2-fans-1-connection/#findComment-4146146
Suppose I connect two fans (with an adapter) to only one fan-header of my motherboard. Will they be able to do their most, or they will be sharing power and working below  their max r.p.m.??
If you have a newer ASUS baord, it can control them seperately.
My arsenal: i7-9700k Gaming Rig, an iPhone, and Stupidity.
https://linustechtips.com/topic/305047-2-fans-1-connection/#findComment-4146150
