Probably not.
The best way to set up a dedicated minecraft sever would be to find an old PC, with maybe a core 2 duo or even possibly something worse, make sure it has about 4 gig of ram, and then install linux, and go to town.
The first step to insanity is believing in your sanity.
https://linustechtips.com/topic/305026-raspberry-pi-2-questions/#findComment-4145817
The most ive been able to get out of my Pi is a home media server controlled from my phone everything else i tried was a total failure because it was either way to expensive or just flat out didnt work nice enough. Ive heard people using them in home automation alot too.
I have an old Pi model B i got last year and that just sucked at minecraft but i never tried running a sever in it so maybe it will?
Current: R2600X@4.0GHz\\ Corsair Air 280x \\ RTX 2070 \\ 16GB DDR3 2666 \\ 1KW EVGA Supernova\\ Asus B450 TUF
Old Systems: A6 5200 APU -- A10 7800K + HD6670 -- FX 9370 + 2X R9 290 -- G3258 + R9 280 -- 4690K + RX480
https://linustechtips.com/topic/305026-raspberry-pi-2-questions/#findComment-4145832
It will run a basic server. I mean basic.
No plugins or anything extravagant.
but for a couple of people (maybe up to about 10) who just want to play vanilla minecraft together in a living room, its perfect. I used to run a 10 player minecraft server on 1GB of RAM and a 2.8GHz Pentium 4. crashed like every couple of hours, but it worked.
"If a Lobster is a fish because it moves by jumping, then a kangaroo is a bird" - Admiral Paulo de Castro Moreira da Silva
"There is nothing more difficult than fixing something that isn't all the way broken yet." - Author Unknown
Intel Core i7-3960X @ 4.6 GHz - Asus P9X79WS/IPMI - 12GB DDR3-1600 quad-channel - EVGA GTX 1080ti SC - Fractal Design Define R5 - 500GB Crucial MX200 - NH-D15 - Logitech G710+ - Mionix Naos 7000 - Sennheiser PC350 w/Topping VX-1
https://linustechtips.com/topic/305026-raspberry-pi-2-questions/#findComment-4147198
