PCPartPicker part list: http://pcpartpicker.com/p/W62Ryc
CPU: Intel Core i5-4690K 3.5GHz Quad-Core Processor
CPU Cooler: CRYORIG R1 Universal 76.0 CFM CPU Cooler
Thermal Compound: Arctic Silver 5 High-Density Polysynthetic Silver 3.5g Thermal Paste
Motherboard: ASRock Z97 EXTREME4 ATX LGA1150 Motherboard
Memory: G.Skill Ares Series 8GB (2 x 4GB) DDR3-1866 Memory
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive
Video Card: MSI GeForce GTX 970 4GB Twin Frozr V Video Card
Case: Fractal Design Define R5 w/Window (Black) ATX Mid Tower Case
Power Supply: EVGA 750W 80+ Gold Certified Fully-Modular ATX Power Supply
Optical Drive: Asus DRW-24B1ST/BLK/B/AS DVD/CD Writer
Total: $1096.74
My budget ~$1000 USD
Please leave any suggestions as well as parts where I can save some money since I'm already slightly over budget
:D  :D  :D  :D  :D  :D
https://linustechtips.com/topic/304975-my-first-build/
Arcic Silver 5 is outdated, use Arctic MX-4 or Noctua NT-H1 or the stuff that comes with your CPU cooler.
Try to squeeze a SSD in there. It's well worth it.
Other than that it looks good. Don't know if you care about the GTX 970s flaws... ;)
who cares...
https://linustechtips.com/topic/304975-my-first-build/#findComment-4145213
CPU: Intel Core i5-4690K 3.5GHz Quad-Core Processor  ($214.95 @ SuperBiiz)
Motherboard: ASRock Z97 EXTREME4 ATX LGA1150 Motherboard  ($110.98 @ Newegg)
Storage: Crucial MX100 256GB 2.5" Solid State Drive  ($99.99 @ SuperBiiz)
Video Card: Gigabyte Radeon R9 290X 4GB WINDFORCE Video Card  ($279.99 @ Newegg)
Total: $1030.84
Generated by PCPartPicker 2015-02-05 14:59 EST-0500
IMO, much better
https://linustechtips.com/topic/304975-my-first-build/#findComment-4145252
Motherboard: Asus Z87-A ATX LGA1150 Motherboard  ($65.00 @ Newegg)
Memory: Kingston Fury Series 8GB (2 x 4GB) DDR3-1600 Memory  ($61.99 @ SuperBiiz)
Video Card: Asus GeForce GTX 970 4GB STRIX Video Card  ($326.99 @ SuperBiiz)
Optical Drive: Asus DRW-24B1ST/BLK/B/AS DVD/CD Writer  ($14.98 @ OutletPC)
Total: $925.75
Generated by PCPartPicker 2015-02-05 15:01 EST-0500
INTEL CORE I5 4670K | NVIDIA GTX 980 | NOCTUA NH-L9i | GIGABYTE GA-Z97X-SLI | KINGSTON 120GB V300
CM STORM QUICKFIRE TK | BENQ XL2420TE | ROCCAT SAVU | FRACTAL DEFINE R4
https://linustechtips.com/topic/304975-my-first-build/#findComment-4145263
Thanks for the advice. Could you maybe use a z97 mobo instead?
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive  ($43.99 @ SuperBiiz)
Total: $925.75
:D  :D  :D  :D  :D  :D
https://linustechtips.com/topic/304975-my-first-build/#findComment-4145345
