I am having a problem, where when I am doing a benchmark in Valley my PSU (which is a Corsair GS700) makes loud electrical noise after the benchmark starts. I have recently added a GTX 970 about a weeks ago and only today have I noticed the noise. I tried running the Valley Benchmark with V-Sync enabled which did help the noise, which led me to believe that this could be coil whine? but I figured I would check here just to be sure! I appreciate any opinions and responses! Thanks in advanced!
https://linustechtips.com/topic/304810-psu-making-electrical-noise/
It is probably coil whine, i have it too when running the 970 on valley.
Rig: I5-3570K@4.3Ghz - Cooler Thermaltake Frio Advanced - Ram Kingston 1333Mhz 8gb (2x4) - GPU GTX 970 4GD5T OC - Motherboard Z77MA-G45 - PSU CoolerMaster GX II 750w - Storage WD 500gb HDD - Sound Edifier M3700 5.1 - Headset Corsair Vengeance 1500 - Mouse Razer Deathadder 2013 - Keyboard Razer Anansi - Mousepad Steelseries QcK+ - Xbox 360 Wireless Controller x2
What anime is your pic from ?????
  ﷲ   Muslim Member  ﷲ
KennyS and ScreaM are my role models in CSGO.
CPU: i3-4130 Motherboard: Gigabyte H81M-S2PH RAM: 8GB Kingston hyperx fury HDD: WD caviar black 1TB GPU: MSI 750TI twin frozr II Case: Aerocool Xpredator X3 PSU: Corsair RM650
Try using a toilet paper cone and put that over your ear and try to scan for the noise source.
My Corsair TX750 is making fan noises, and my friend's CX series was whining as well. So I guess that is common in Corsair PSU's. Good thing that their customer support is superb though :P
To aru majutsu no index/To aru kagaku no railgun (Railgun is side-story of index)
To aru no Railgun.
To aru no Index
IS it any good ????????
  ﷲ   Muslim Member  ﷲ
Index is good, yes, but railgun is SUPERB. Best anime i've seen in a long time(and i've seen a lot). You really don't need to watch a lot of Index to watch railgun, i totally recommend it. Head over the anime club for any other question/recommendation if you want :)
Thanks.
  ﷲ   Muslim Member  ﷲ
thankfully is not water noise. :lol:
Troll mode On
CORE i5 4670K ASRock Fatal1ty KILLER 8GB CORSAIR VENGEANCE PRO  MSI GTX 770 7TEAM 550W
AMD FX6300 GA 990FXA-UD3 4.0 16GB G.SKILL TridentX  EVGA 9600 GT EVGA SN 750W G2
