Hi,
I'm planning to add two more radiators so I can run my fans even more quiet, or even completely off when I'm not "doing anything", this will result in a total of 3x Alphacool UT60 140x4 radiators and 1 Alphacool UT60 120x4 radiator. With 1 or 2 fullcover gpu blocks, and a monoblock for ASUS rampage iv BE + cpu.
My question is, will two D5 pumps in serial be able to get a good flow with this much restriction?
Thank you
//NE0XY
https://linustechtips.com/topic/304277-pump-question/
Hi,
Thank you
//NE0XY
Hi. Yes, it should be fine.
https://linustechtips.com/topic/304277-pump-question/#findComment-4135252
Well a single pump may be able to overcome that restriction, but it might need to be set higher to do so, meaning it could also be louder. A second pump could allow for better flow at a lower setting, but that'll depend on how much restriction the new radiators and the tubing to reach them introduce -- shouldn't be much, but it might be. Let your temperatures be your guide on that one. The pump will be louder the higher you go, and since you're aiming for a more silent build, a second pump might be worthwhile if you have to have a single D5 up near the highest setting to get good flow.
Wife's build: Amethyst - Ryzen 9 3900X, 32GB G.Skill Ripjaws V DDR4-3200, ASUS Prime X570-P, EVGA RTX 3080 FTW3 12GB, Corsair Obsidian 750D, Corsair RM1000 (yellow label)
My build: Mira - Ryzen 7 3700X, 32GB EVGA DDR4-3200, ASUS Prime X470-PRO, EVGA RTX 3070 XC3, beQuiet Dark Base 900, EVGA 1000 G6
https://linustechtips.com/topic/304277-pump-question/#findComment-4135780
 Sorry, maybe I wasn't clear. I already have two pumps running on 50% for normal operations and atleast 80-90% when gaming So I'm worried that I have to have the pumps constantly at 80% for normal operations with the new radiators etc. And also to be "future proof" In case I add another graphics card.
https://linustechtips.com/topic/304277-pump-question/#findComment-4135952
No you should not worry about that. Two pumps is still going to be overkill for what you're ending up with along with what you've already got.
https://linustechtips.com/topic/304277-pump-question/#findComment-4136694
