What's the difference between Base and Boost Clock speeds?
Read the LTT Beginner's Guide; it's like a guide on how to not be a moron
 CPU: i5-4690k 4.1 GHz CPU Cooler: Cooler Master 212 EVO GPU: Asus Gtx 970 Strix MOBO: ASUS Z97-E RAM: Crucial Ballistix Sport 16GB (2 x 8GB) 1600 SSD: Samsung 840 Evo 500GB HDD: Seagate Barracuda 1TB PSU: Cooler Master 600W 80+ Bronze Case: Cooler Master Storm Scout 2 Advanced
https://linustechtips.com/topic/303826-base-clock-and-boost-clock/
Base clock speed is what the card is designed to run at all the time, aside from when being throttled
Boost clock speed is what the card can clock up to if conditions (temps) are preferable
"Rawr XD"
base clock means the GPU is is non hardcore mode, meaning it is not using its full potential, saving energy and producing les heat. Boost is used when the GPU needs raw horsepower, it will use more power. YOu can force it to always use boost, for example overclocking and forcing it to stay, but it is unproductive and stupid. THe GPu knows when an application needs the boost speeds and when not.
Planning on trying StarCitizen (Highly recommended)? STAR-NR5P-CJFR is my referal link
Ok well my Asus 970 has never gone above 1170 MHz but it has a boost clock of 1253?
Because it can´t you bottleneck it with that CPU that´s all.
Intel i7 7820X (delidded) @ 4.9GHz - MSI X299 M7 ACK + EKWB Fullcover Block - G.Skill Trident Z 32GB @ 3466MHz - nVidia Titan Xp + EKWB Fullcover Block @ 2.1GHz - Samsung 960Pro 2x - WDD Blue 2TB - Seasonic 750W Platinum - modded Corsair 600C - Hardtubed Custom Watercooling
Bottlenecking should be determined by GPU usage not clock speeds
"Rawr XD"
Well yeah but if the the GPU can´t be used 100% it won´t boost that high.
