Blower vs Reference coolers for SLI
Solved by Xaring,
I would have thought it would have been the top card that would struggle for air in that setup not the bottom one? I wanted to use aftermarket coolers for the high clock speeds, mixing them would rule that out.
The SG10 only has 4 PCI slots so running with a space inbetween is out.
YOu can do that, but then the hot air from the bottom GPU will raise and go into the top one, causing it to thermal throttle in the worse cases, if you exhaust backwards on the botton, youve, still have completely fresh ar sucked in on the top one (it does not matter if its aftermarket, whci would have higher clock speed and a better cooler, or a reference)
