Hello everyone - so im planning to upgrade my cooling since i´ve ordered a r9 290x
i got a 300r case , and atm i got one 140 intake in the front and a 120 outtake at the back.
So what i was thinking about doing was going with 140 intake on the side panel and a 140 outtake at the top but since i dont have a lot of experience with cooling , i would like to ask here , if you guys think that is fine , or if i should go with something else like
120 rear outtake 2*140 front intake and a single or 2 120 or 140 outakes in the top?
i dont really know what would be best .
Besides that im also looking to get a CPU cooler , where i cant deside between the Dark rock 3 and the dark rock pro 3( i´ve also been looking a bit at the Noctua D15 , but it´s just so ugly , and since im gonna move to a windowed case at some point , i will mind it at some point)
At last i would like to ask what is your opinion on who makes the best fans , besides Noctua  :)
https://linustechtips.com/topic/303740-help-with-cooling-upgrade/
Well Noctua makes those black/gray fans too you know :) but Coolermaster, Corsair ... probably others too.
Edit: BitFenix has some good ones too.
Where are you shopping/located? Budget?
http://www.webhallen.com/se-sv/
https://www.komplett.dk/k/k.aspx
my budget is around 800 kr
or what would be 120$
NF-S12B redux: https://www.komplett.dk/noctua-nf-s12b-redux-1200-pwm-120mm/816924
1 for upper front intake; 2 for side intake; 2 for rear and top exhaust
NF-P14s for lower front intake: https://www.komplett.dk/noctua-nf-p14s-redux-1200-pwm-140mm/816916
i´ll try that :3 . thx a lot :)
do you kno Do you know how Dark rock 3 and dark rock 3 pro and NH D15 compares to eacher other ,
is it worth the extra money?
is it worth the extra money?  , i could also just buy a hyper evo 212 and get an ssd
This should help:
http://www.overclockersclub.com/reviews/be_quiet_dark_rock_3/4.htm
http://www.frostytech.com/articleview.cfm?articleid=2766&page=5
Definitely go with a cheaper cooler if it would mean you could get a ssd.
I'd suggest the similarly performing but quieter Pure Rock: http://www.webhallen.com/se-sv/datorkomponenter/209949-be_quiet_pure_rock_cpu_kylare
This should help:
ok , thx :3 .
on last thing tho
i was going to conrol all of the fans with a Lamptron FC5 V2 but i realised it got 3 pin outputs , and the fans are PWM .
first - will i be able to connect them anyway .
second - should i consider another controller? or just get 3 pin fans?
ok , thx :3 .
on last thing tho
3pin and 4pin are backwards compatible as long as the 3pin connector doesn't have a physical restriction like the plastic housing being too small/big.
  • 2 weeks later...
Hei - so i finally got my fans today - and i realized i cant get both a 120 and a 140 in the front only 2 120 or 2 140 - so should i just get another 140 and put 2 140 in the front -
and by "2 for rear and top exhaust" did you then mean 1 rear exhaust and 1 top exhaust or 1 rear and 2 top ?
thx again :)
thx again :)
Oh, I didn't notice the 120mm mounts weren't centered--my bad. Swap the 140mm with the top exhaust S12B.
I meant 1 exhaust for the top and the another for the rear.
