970 load issues on BF4
Go to solution Solved by JamesYang,
I have heard that the FX series are pretty awful. I'm not to tight for a budget, I can sell my mobo and cpu I have a reasonably large influx of money coming soon. What Intel processor is good? (less than £200 please)
Not on budget should've gone with Intel at the beginning...If you're not overclocking,just for gaming,grab i5 4690K/i5 4690/i5 4590/i5 4460(Price Hight to Low),and motherboard,you can check out Linus's Channel's 3 Parts; Bang for the Buck Z97 Motherboard Showdown Part 1,Part 2,Part 3 watch the video and choose for yourself,though I'd recommend ASUS Z97-C
That bloody bottleneck from the CPU. This is why you go on forums to ask people about bottlenecks before you get a PC, upgrade your CPU AFAP to an i3 and a cheap H81/H97 motherboard (depending on the CPU's architecture).
https://linustechtips.com/topic/303708-970-load-issues-on-bf4/#findComment-4127701
You guessed it.
Low load even on ultra, running at 1080p getting fps from 30-50
Specs:
CPU: 7850k
GPU: Gigabyte Windforce 3 970
RAM: 8gb @ 1600mhz
PSU: 600w evga
CPU mate.
I have the 970 and im getting 80FPS on with ultra on 1080p monitor running 1440p DRS
If i run 1080p on ultra i go in the hundreds for FPS
GPU: EVGA GeForce GTX 980 4GB Superclocked ACX 2.0 @1500mhz + 8000Mhz CPU: Intel Core i7 6700k Delided and Overclocked @4.8  MB: ASUS MAXIMUS VIII IMPACT  RAM: Corsair Vengeance LPX 16GB (2 x 8GB) DDR4-2400 Memory CPU Cooler: Corsair HG10+ H90 +H90 CASE: Corsair 380T  Storage: 120GB Samsung Evo SSD + Crucail 256GB Mx100 + 2TB Seagate/  OS: Windows 10 64bit Power supply:  Corsair RM750
https://linustechtips.com/topic/303708-970-load-issues-on-bf4/#findComment-4127703
@Appel
Your CPU is MUCH too weak to even come close to supporting a 970. You need to upgrade
RIG: I7-4790k @ 4.5GHz | MSI Z97S SLI Plus | 12GB Geil Dragon RAM 1333MHz | Gigabyte G1 Gaming GTX 970 (1550MHz core/7800MHz memory) @ +18mV(Maxed out at 1650/7800 so far) | Corsair RM750 | Samsung 840 EVO 120GB, 1TB Seagate Barracuda | Fractal Design Arc Midi R2 (Closed) | Sound Blaster Z        Getting: Noctua NH-D15 | Possible 250GB Samsung 850 Evo        Need a console killer that actually shits on every console? Here you go (No MIR/Promo)
This is why you should not get an FX CPU for ANY scenario other than rendering on a budget http://linustechtips.com/main/topic/286142-fx-8350-r9-290-psu-requirements/?p=3892901 http://linustechtips.com/main/topic/266481-an-issue-with-people-bashing-the-fx-cpus/?p=3620861
https://linustechtips.com/topic/303708-970-load-issues-on-bf4/#findComment-4127709
I don't knwo if you use on-screen display in MSi Afterburner but check to make sure your not frame limiting the game.
https://linustechtips.com/topic/303708-970-load-issues-on-bf4/#findComment-4127739
The CPU is a gigantic bottleneck... That 970 is probably crying for a better CPU.
Senor Shiny: Main- CPU Intel i7 6700k 4.7GHz @1.42v | RAM G.Skill TridentZ CL16 3200 | GPU Asus Strix GTX 1070 (2100/2152) | Motherboard ASRock Z170 OC Formula | HDD Seagate 1TB x2 | SSD 850 EVO 120GB | CASE NZXT S340 (Black) | PSU Supernova G2 750W  | Cooling NZXT Kraken X62 w/Vardars
Secondary (Plex): CPU Intel Xeon E3-1230 v3 @1.099v | RAM Samsun Wonder 16GB CL9 1600 (sadly no oc) | GPU Asus GTX 680 4GB DCII | Motherboard ASRock H97M-Pro4 | HDDs Seagate 1TB, WD Blue 1TB, WD Blue 3TB | Case Corsair Air 240 (Black) | PSU EVGA 600B | Cooling GeminII S524
(Deceased) DangerousNotDell- CPU AMD AMD FX 8120 @4.8GHz 1.42v | GPU Asus GTX 680 4GB DCII | RAM Samsung Wonder 8GB (CL9 2133MHz 1.6v) | Motherboard Asus Crosshair V Formula-Z | Cooling EVO 212 | Case Rosewill Redbone | PSU EVGA 600B | HDD Seagate 1TB
DangerousNotDell New Parts For Main Rig Build Log, Señor Shiny  I am a beautiful person. The comments for your help. I have to be a good book. I have to be a good book. I have to be a good book.
https://linustechtips.com/topic/303708-970-load-issues-on-bf4/#findComment-4127791
Thats also AMD's newest one! (I believe)
you could try to OC the APU speed and see if the fps will improve
Budget? Uses? Currency? Location? Operating System? Peripherals? Monitor? Use PCPartPicker wherever possible.
Quote whom you're replying to, and set option to follow your topics. Or Else we can't see your reply.
https://linustechtips.com/topic/303708-970-load-issues-on-bf4/#findComment-4130571
Well, my cpu is water cooled so I could try that, but I don't really want to kill it :c
at stock voltage you should be able to bump it up to 4.1GHz
Disable Turbo Boost, Enable Cool & Quiet mode
Disable C6 state and enable Advance Power Management
clock the System Bus speed to 2GHz
and play with the multiplier
bump it up to 1.4+ volts if you want to hit the 4.3-4.5GHz mark
https://linustechtips.com/topic/303708-970-load-issues-on-bf4/#findComment-4132457
CPU Architecture Shootout: 16 CPUs, One Core Each, And 3 GHz
http://www.tomshardware.com/reviews/processor-architecture-benchmark,2974.html
Date - 2011, so Sandy Bridge is used, as well as AMD's prior to FX series type CPU's, (which I'm pretty sure can even be faster than FX in some cases or barely behind)
Analizing FX - http://www.extremetech.com/computing/100583-analyzing-bulldozers-scaling-single-thread-performance
@Faceman has the collaborated info from different users/sources and put it into a thread WORTH READING.
http://linustechtips.com/main/topic/266481-an-issue-with-people-bashing-the-fx-cpus/page-5#entry3621417
Maximums - Asus Z97-K /w i5 4690 Bclk @106.9Mhz * x39 = 4.17Ghz, 8GB of 2600Mhz DDR3,.. Gigabyte GTX970 G1-Gaming @ 1550Mhz
https://linustechtips.com/topic/303708-970-load-issues-on-bf4/#findComment-4132468
So what do I look for in a CPU to support my 970?
cores?
Ghz?
Other things?
No,You don't need to do that,but you do need to look carefully about the product,what it's made for.
If your budget is tight,go with amd is definitely your best choice,but not APU,APU is sort of made for HTPC.
If you can,sell your current CPU and Motherboard,and take that money(You maybe need to pay a few bucks more) to go buy a AMD FX series CPU(At least FX 8320 or higher),and a AM3+ Motherboard 990 Chipset,970 chipset is a bit old,but msi has a gaming board,if you like its feature.
https://linustechtips.com/topic/303708-970-load-issues-on-bf4/#findComment-4133461
https://linustechtips.com/topic/303708-970-load-issues-on-bf4/#findComment-4133840
https://linustechtips.com/topic/303708-970-load-issues-on-bf4/#findComment-4134149
