help with canadian keyboard
Go to solution Solved by awesomes8wc3,
Don't put in your email address.
Hit create new account, and then create local account.
Hi all, Just bought a UX303LN from canada it has windows 8.1 and on the setup screen it asks for me to put in my email address, i cant because shift+2 doesnt make the @ sign, i know i can change this once i have the computer set up but i cant set it up because of this
Does anyone know how to make the @ sign??
Thanks
https://linustechtips.com/topic/302849-help-with-canadian-keyboard/
Alt+2 or ctrl+alt+2 usually work
it might also work if you ask it politely...eh?
Nope :( alt+2 & alt+ctrl+2 both do nothing, as in nothing even comes up in the text box. Thanks anyway
not even right alt +2?
Damn it i had this problem too but I can't remember how I got past it.
can you skip the account log in and do it after the setup in 8.1?
now that im in, is there a program any of you know about that i can permanently fix this? so that when i do shift+2 is is always @
you could change the keyboard layout in windows?
pc specs: 4 function calculator / 8 digit lcd display / colored numeric and function buttons
