BF3 and 4 low FPS
Solved by AndyE,
Try this:
1. Open up notepad
2. Copy this into it:
GameTime.Maxvariablefps x (replace the x with one more than your monitors refresh rate. For example mine would be GameTime.Maxvariablefps 61 because I have a 60 htz monitor)
3. Save it in the bf4 install directory as a .cfg file
Thats how you make console commands permanent, and that is the command for framerate limit. Not sure if it will fix your framerate problem though.
