Perhaps AMD's APUs. Maybe the Richland ones in particular. If you go that route, make sure you get higher clocked RAM. HIgher clocked, the better.
https://linustechtips.com/topic/30107-system-suggestions/#findComment-384964
no no, for $800 you can build a whole gaming machine.
955/965BE cpu, $100
Cheapo 970 or 990 mobo, $100
some ram, as long as it works, $60
7870 or 7950, $200-$300
a decent 500-550W psu, $65
cheap case, $100
You should have a hard drive already.. A 1TB hdd is like $65 if you don't
and Windows $100
$790-$890
Right?
Edit: Newegg is selling a Sapphire 7970 for $300. Steal your relative's ram and hdd!
https://linustechtips.com/topic/30107-system-suggestions/#findComment-385353
AMD a10-5800k  $130
FM2 board  $100
7870/7950  ($270 for 7950)
8GB ram $70
Cheap case $50 - 100
PSU $70
HDD and disk drive $70
a10 was anandtech's best budget cpu for gaming a few weeks ago
i7 4770k, 16GB Corsair Vengeance
Gigabyte z87, Phanteks Enthoo Primo
7970
https://linustechtips.com/topic/30107-system-suggestions/#findComment-388722
Well here is a list of components i selected to try and give you a half decent Intel mild gaming rig for around 800 bucks (sorry just over)
      youraccount.gif  *All prices in Canadian dollars.
 *No additional duties or fees.
QTY
AVAILABILITY
SAVINGS
TOTAL
pixel-clr.gifdelete_button.gif C13-CX500M_chiclet01_ac_mn_7564402.jpgC13-CX500M ::Corsair CX Series CP-9020059-NA 500W Power Supply - 80+ Bronze, ATX, Modular Cabling, Active PFC, Single +12V Rail, Low Noise, Trouble-free Installation (3.95 lbs) pixel-clr.gif
In Stock
Details
$69.97
pixel-clr.gifpixel-clr.gif     pixel-clr.gifdelete_button.gif C283-3122_chiclet01_aa_6430030.jpgC283-3122 ::Cooler Master Elite 430 Mid Tower ATX Case - ATX/Micro-ATX, USB, Audio, 120mm Blue LED Fan, Black (RC-430-KWN1)(13.3 lbs) pixel-clr.gif
In Stock
Details
$49.97
pixel-clr.gif$10.00 Mail-in Rebate pixel-clr.gif     pixel-clr.gifdelete_button.gif E145-0650_chiclet01xx_gfv_mn_4501123.jpgE145-0650 ::EVGA GeForce GTX 650 01G-P4-2650-KR Video Card - 1GB GDDR5, PCI-Express 3.0(x16), 1x Dual-link DVI-I, 1x Dual-link DVI-D, 1x Mini-HDMI, DirectX 11, Dual-Slot(1.6 lbs) pixel-clr.gif
In Stock
Details
$114.97
pixel-clr.gif$10.00 Mail-in Rebate pixel-clr.gif     pixel-clr.gifdelete_button.gif TMD-1000AS6_chiclet01_ibp_mn_7750549.jpgTMD-1000AS6 ::Seagate 1TB Solid State Hybrid Drive - 2.5" Form Factor, SATA III 6 Gb/s, 5400 RPM, 64MB Cache (ST1000LM014)(0.4 lbs) pixel-clr.gif
In Stock
Details
$119.97
pixel-clr.gif$20.00 Mail-in Rebate pixel-clr.gif     pixel-clr.gifdelete_button.gif M17-7302_chiclet01x_er.jpgM17-7302 ::Microsoft Windows 7 Home Premium GFC-02050 Operating System Software - 64bit, DVD(0.8 lbs) pixel-clr.gif
In Stock
Details
$99.99
pixel-clr.gifpixel-clr.gif     pixel-clr.gifdelete_button.gif K24-0107_chiclet01_ac_mn_3865543.jpgK24-0107 ::Kingston HyperX Red KHX16C9B1RK2/8X 8GB Memory Module Kit - 1600MHz, 9-9-9, DDR3, 2x4GB, CL9, 1.65V, Unbuffered(0.2 lbs) pixel-clr.gif
In Stock
Details
$59.97
pixel-clr.gifpixel-clr.gif     pixel-clr.gifdelete_button.gif I69-LIQUID-chicklet00-aa.jpgYYI2-47777Q ::Intel BXRTS2011LC High Performance Liquid Cooler - 120mm Fan, 2200 RPM Max, 74 CMF, 35dBA Max, 150mm Radiator, LGA2011, LGA1155(2.7 lbs) pixel-clr.gif
Usually Ships within 48 Hours
Details
$92.99
pixel-clr.gifpixel-clr.gif     pixel-clr.gifdelete_button.gif I69-3220_chiclet01_aa_mn_3734679.jpgI69-3220 ::Intel BX80637I33220 Core i3-3220 Processor - Dual Core, 3MB L3 Cache, 3.30GHz, Socket H2 (LGA1155), 55W, 650-1050 MHz, Fan(0.65 lbs) pixel-clr.gif
In Stock
Details
pixel-clr.gifdelete_button.gif A455-8414_chiclet01_aa_2522291.jpgA455-8414 ::ASUS P8Z77-M Intel Z77 Motherboard - Micro ATX, Socket H2 (LGA1155), Intel Z77 Chipset, 2400MHz DDR3 (O.C.), SATA 6.0 Gb/s, 8-CH Audio, Gigabit LAN, USB 3.0, PCI-E 3.0, CrossFireX Ready(2.3 lbs) pixel-clr.gif
In Stock
Details
$141.17
Total $878.97
A Smidge over 800 but under 900.
you could get a cheaper cooler, and you would need some extra case fans, but the main things are there and sorry no USB 3.0 on the case its so cheap that if you want a usb header case with a side window it will be a little more money.
hope it helps.
got to love Asus components
https://linustechtips.com/topic/30107-system-suggestions/#findComment-390480
Post is messed up.
https://linustechtips.com/topic/30107-system-suggestions/#findComment-390482
