What cases would you guys recommend? I need ample space (2xGTX 970). I assume that this would only fit into a full tower, but please correct me if I'm wrong.
Color should be black, grey, or white. Nothing really too outlandish.
Design-wise I'd prefer something simpler.
Any help is appreciated :)
https://linustechtips.com/topic/301065-tower-help/
Budget?
Window?
RIG: I7-4790k @ 4.5GHz | MSI Z97S SLI Plus | 12GB Geil Dragon RAM 1333MHz | Gigabyte G1 Gaming GTX 970 (1550MHz core/7800MHz memory) @ +18mV(Maxed out at 1650/7800 so far) | Corsair RM750 | Samsung 840 EVO 120GB, 1TB Seagate Barracuda | Fractal Design Arc Midi R2 (Closed) | Sound Blaster Z        Getting: Noctua NH-D15 | Possible 250GB Samsung 850 Evo        Need a console killer that actually shits on every console? Here you go (No MIR/Promo)
This is why you should not get an FX CPU for ANY scenario other than rendering on a budget http://linustechtips.com/main/topic/286142-fx-8350-r9-290-psu-requirements/?p=3892901 http://linustechtips.com/main/topic/266481-an-issue-with-people-bashing-the-fx-cpus/?p=3620861
https://linustechtips.com/topic/301065-tower-help/#findComment-4091219
Enthoo pro
Air 540
750d
H440
Define R series
Etc.
Those will fit in almost any atx mid or full tower.
https://linustechtips.com/topic/301065-tower-help/#findComment-4091229
Budget: I'd prefer if it stayed close to or under $150.
Window is unnecessary but welcome.
760/780T
450D
H440 (silence)
Define R5 (silence)
Arc midi R2
The cases marked as silence have lesser airflow but more silence
https://linustechtips.com/topic/301065-tower-help/#findComment-4091272
Enthoo pro
Enthoo luxe
Ft05
https://linustechtips.com/topic/301065-tower-help/#findComment-4091444
