Hello everyone!
I've been meaning to get a a rig together for quite a while, it will be mainly a gaming machine, i play CSGO competitively but i do play some other more graphics demanding games like FC3 and so on.
My budget is 1600€ and I'll be buying everything from a local retailer, http://www.alientech.pt/
These are all the parts I've put together.
CPU: Intel Core i5-4690K
Mobo: Asus SABERTOOTH Z97 MARK2
RAM: Kingston HyperX Beast 8GB
PSU: Corsair RM 650W
GPU: Asus GeForce GTX 970 4GB STRIX
HD: Western Digital Caviar Blue 1TB
SDD: Samsung 840 EVO 120GB
CPU Cooler: Cooler Master Nepton 240M
Case: NZXT S340
Monitor: BenQ XL2411Z
The total price is 1580€
Thoughts and suggestions are appreciated.
read everytihng, say nothing.
https://linustechtips.com/topic/300569-first-build-help/
Go with a cheaper motherboard -- pretty much all Z97 boards (from Asus, MSI, Gigabyte, and AsRock) are equivalent if it they support the same features (SLI. XFIRE, # of sata ports, I/O, etc...)
and cheaper psu -- either an EVGA B1/Corsair CX/Seasonic/Cooler Master 80+bronze unit on the budget end, or something like an EVGA G2 750w psu on the high end.
Although I would personally go fir an i7-4790k + hyper 212 rather than a 4690k+nepton 240m.
PSU Tier List | CoC
Gaming Build | FreeNAS Server
https://linustechtips.com/topic/300569-first-build-help/#findComment-4083411
Don't get me wrong the system is really good but 1600€ is kinda overpriced portugal must suck with Hardware pricing
CPU: Xeon 1230v3 - GPU: GTX 770  - SSD: 120GB 840 Evo - HDD: WD Blue 1TB - RAM: Ballistix 8GB - Case: CM N400 - PSU: CX 600M - Cooling: Cooler Master 212 Evo
Update Plans: Mini ITX this bitch
https://linustechtips.com/topic/300569-first-build-help/#findComment-4083448
For everyone that thinks im an AMD FANBOY.
CPU: Intel Core i5-4690K 3.5GHz Quad-Core Processor  ($219.95 @ SuperBiiz)
Motherboard: Asus Z87-A ATX LGA1150 Motherboard  ($75.99 @ NCIX US)
Memory: Crucial 4GB (1 x 4GB) DDR3-1600 Memory  ($29.99 @ Newegg)
Video Card: PNY GeForce GTX 970 4GB XLR8 Video Card (2-Way SLI)  ($324.88 @ OutletPC)
Case: Zalman Z3 Plus White ATX Mid Tower Case  ($59.99 @ Newegg)
Total: $1214.40
Generated by PCPartPicker 2015-01-29 14:36 EST-0500
Add your prefered peripherals and OS now.
https://linustechtips.com/topic/300569-first-build-help/#findComment-4083459
Total: $1214.40
He's not in the US. Also, a Z87 board could potentially require a bios update making it not worth the money saved by going with it (although he should get a cheaper z97 board -- MSI Z97s SLI Plus, G55 SLi, Gigabyte Z97x SLI, Asus Z97-A, Z97-E, Z97-AR).
PSU Tier List | CoC
https://linustechtips.com/topic/300569-first-build-help/#findComment-4083463
PSU Tier List | CoC
https://linustechtips.com/topic/300569-first-build-help/#findComment-4083522
The Z97m doesn;t support SLI.
Check one of these (one will probably be the cheapest option with SLI support):
Gonna look for it.
Im glad i can speak portuguese :D
https://linustechtips.com/topic/300569-first-build-help/#findComment-4083530
What do you think @djdwosk97
EDIT : I need to remove the SSD to give space to buy the monitor.
I'd go with a WD blue /seagate barracuda rather than a green. Everything else looks good -- and I'm assuming you found the cheapest/most cost effective options.
PSU Tier List | CoC
https://linustechtips.com/topic/300569-first-build-help/#findComment-4083608
Yes .
I took the SSD out for the OP get a monitor but he can buy one later.
https://linustechtips.com/topic/300569-first-build-help/#findComment-4083611
Yes .
Well, it might be worth losing one of the 970s and going with an ssd -- depending on what other games he plays.
PSU Tier List | CoC
https://linustechtips.com/topic/300569-first-build-help/#findComment-4083632
I will swap it with a faster HDD then.
https://linustechtips.com/topic/300569-first-build-help/#findComment-4083646
ok, i like this. is 600w plenty for both 970s?
Yes, 600w is fine for SLI 970s.
Don't bother going with anything faster than a blue / barracuda.
PSU Tier List | CoC
https://linustechtips.com/topic/300569-first-build-help/#findComment-4083658
The blues are 90 euros .
I swaped with a seagate HDD.
https://linustechtips.com/topic/300569-first-build-help/#findComment-4083671
