My fan extension wire is hot near the end, and it looks like the rubber around the wire is missing at the end.
SHould i not use it?
https://linustechtips.com/topic/300396-wire-hot/
Maybe the wires inside make contact, better get a new one, a cable fire inside something with a lot of cables is not so good
CPU: Xeon 1230v3 - GPU: GTX 770  - SSD: 120GB 840 Evo - HDD: WD Blue 1TB - RAM: Ballistix 8GB - Case: CM N400 - PSU: CX 600M - Cooling: Cooler Master 212 Evo
Update Plans: Mini ITX this bitch
https://linustechtips.com/topic/300396-wire-hot/#findComment-4080561
Hot and insulation is missing? You have a short circuit right there.
Toss that thing away before anything catches fire.
60FPS Microwave
Intel Core i5-4670K | Galax GTX 970 EXOC | ASRock Z97E-ITX/ac | Team Elite 8GB 1600MHz | Gelid Black Edition | Samsung slowdown + WD Blue 1TB x2 | Cooler Master V550 | Corsair K65 + Logitech G100s | MasterCase Pro 3
https://linustechtips.com/topic/300396-wire-hot/#findComment-4080576
