Not really. Most high-end boards have a good audio solution already installed. The ROG brand uses dedicated soundcards intergrated into the PCB or in some cases a daughter-board (Like the Impact series)
#LinusKitchenTips /// "Better than useless" - Linus Sebastian
LTT Holy bible: Code Of Conduct
Project Toaster [My Silver NCASE M1 V2 Build-log]
Main Rig
 Case: Fractal Design Define R5 CPU: INTEL
i5 3570k Cooler: CM Hyper 212 Evo Mobo: Maximus V Gene Z77 GPU: Gigabyte GTX 970 G1 Gaming (w/ 0% fan mode) RAM: Corsair Dominator Platinum 2x8GB 1600mHz Storage: OCZ VERTEX 4 256GB PSU: Corsair AX860 Monitor: ASUS PB278Q 1440p 27" Headphones: QPAD QH-90 Laptop
Macbook Pro Retina 13" i5 256Gb Early 2015
Phone
Oneplus One 64GB Sandstone Black
https://linustechtips.com/topic/299758-sound-card/#findComment-4071220
I dedicate this to you. Just to you:
https://www.youtube.com/watch?v=cxzBQJQwFd0
I bailed my initial comment lol
Main Rig
Phone
https://linustechtips.com/topic/299758-sound-card/#findComment-4071235
Not worth it. I would consider getting a nice motherboard with a decent onboard chip. That is cheaper, less hassle with drivers and doesn't need any extra space in your PC (which can be a problem depending on the size of your system). Also most onboard solutions are just as good as a dedicated sound card.
PC: AMD Ryzen 7 7700 || Noctua NH-U12S SE2 || 32GB DDR5 6000 CL32  ||
|| Powercolor RX 9070 Reaper || Asus B650E-I
  || WD 850X 2TB ||  Corsair SF600 || Intertech IM 1 |||
Peripherals: Sennheiser PC  360 G4ME || AOC CQ27G2U || Viewsonic PX701HD || Keychron V1 || Logitech G303 Shroud Edition||| Laptop: XPS 13 2in1 7390 || Steam Deck 256 GB (64GB Version) ||| Cameras: Fujifilm XH-1 || Fujifilm X100T
Elite 110 build log (update:05/15/2018)
https://linustechtips.com/topic/299758-sound-card/#findComment-4071237
Exactly what I was thinking! Great profile picture, by the road.
https://linustechtips.com/topic/299758-sound-card/#findComment-4071264
Sound track allow your PC to have better feature, like if you want to install 7.1 surround speaker.
Where I hang out: The Garage - Car Enthusiast Club
My cars: 2006 Mazda RX-8 (MT) | 2014 Mazda 6 (AT) | 2009 Honda Jazz (AT)
PC Specs
Indonesia
CPU: i5-4690 | Motherboard: MSI B85-G43 | Memory: Corsair Vengeance 2x4GB | Power Supply: Corsair CX500 | Video Card: MSI GTX 970
Storage: Kingston V300 120GB & WD Blue 1TB | Network Card: ASUS PCE-AC56 | Peripherals: Microsoft Wired 600 & Logitech G29 + Shifter
Australia
CPU: Ryzen 3 2200G | Motherboard: MSI - B450 Tomahawk | Memory: Mushkin - 8GB (1 x 8GB) | Storage: Mushkin 250GB & Western Digital - Caviar Blue 1TB
Video Card: GIGABYTE - RX 580 8GB | Case: Corsair - 100R ATX Mid Tower | Power Supply: Avolv 550W 80+ Gold
https://linustechtips.com/topic/299758-sound-card/#findComment-4071282
See, I personally noticed a big difference in audio positioning when playing CS:GO when I upgraded to my Creative Z board. I can now pinpoint where people are coming from and even how close where as before I would not be able to. I guess it depends on how the sound is used in your game, but in close-quarters FPS games like CS:GO, I think it helps.
Sometimes i troll...
3D Mark Fire Strike Score: http://www.3dmark.com/fs/3854240 +215mhz Core Clock +440mhz Memory Clock @4.6ghz 1.325v
http://pcpartpicker.com/user/b1aze/saved/qQFxFT
https://linustechtips.com/topic/299758-sound-card/#findComment-4071354
well i heard from some guys saying that add on sound cards like Creative Z cards are banned from FPS tournaments because of the unfair advantage like what you experienced where you can pin point your enemy location
Budget? Uses? Currency? Location? Operating System? Peripherals? Monitor? Use PCPartPicker wherever possible.
Quote whom you're replying to, and set option to follow your topics. Or Else we can't see your reply.
https://linustechtips.com/topic/299758-sound-card/#findComment-4071385
