Hi guys, I need help with choosing a good graphics card. I have bought my other parts and its the last thing I need. It has to look really nice (Preferably a backplate and LED lights on it) and performe nicely. I know you guys will suggest some good graphics cards so let me just put this out there, Im not too concerned with bottlenecking of any kind. As long as I can run games(Crysis3 far cry 3&4, Bf4, etc) at medium to ultra settings at 1080p and maybe do some recording then thats fine for me. My card budget is $200-$300 CAD.
my list of parts that I have:
CPU: Amd athlon x4 860k (Planning to OC it, havent got around to it yet though)
CPU Cooler: Cooler Master Hyper d92
Mobo: Asrock a88x fm2 pro3+ fm2+
Ram: Corsair vengeance 8gb 1600mhz
Case: Corsair Spec 01
PSU: EVGA 600b 600wat psu
SSD: Crucial m500 240gb ssd
HDD: Dont have one yet.
Windows 8
And yes, this is my first build, It is mostly based on looks a bit more than performance.
https://linustechtips.com/topic/299561-need-help-choosing-a-graphics-card/
280X, or GTX 960
My Rig:  CPU: Core i7 4790K @4.8ghz  Motherboard: Asus Maximus Vii Hero  Ram: 4x4GB Corsair Vengeance Pro 2400mhz (Red)  Cooling: Corsair H105, 2x Corsair SP120 High Preformance Editions, Corsair AF 140 Quiet Edition  PSU: Corsair RM 850  GPU: EVGA GTX 980 SC ACX 2.0  Storage: Samsung 840 EVO 120GB, WD Blue 1TB  Case Corsair 760t (Black)  Keyboard: Razer Blackwidow Chroma  Mouse: Razer Deathadder Chroma  Headset: ATH-M50X Mic: Blue Yeti Blackout
280X, or GTX 960
I don't know if that'll do, but how about this: get a 960. Since it has very low tdp, you could downgrade your PSU into the 450W range, and with that money, get a stronger CPU?
The dream? Maybe??
Want to help researchers improve the lives on millions of people with just your computer? Then join World Community Grid distributed computing, and start helping the world to solve it's most difficult problems!
The dream? Maybe??
he has already bought the other parts
his cpu is 860k it will bottleneck r9 280x
He doesn't need a super expensive gpu because that cpu is weak. Max should be a 270X/gtx 760
Personally op I would buy a 750 Ti
Core I7 5960X / Gigabyte X99 SOC Force / Kingston 16GB DDR4 3000 / EVGA GTX 980 Classified's In Quad SLI / EVGA 1600W G2
Core I7 6700K / Asus Z170 Maximus VIII Hero / Corsair 16GB DDR4 3000 / MSI R9 290X Lightning / EVGA 1600W T2
backplate guys. Also I think the 860k can handle more than the 750ti without bottlenecking. budget is up to $300 CAD. Dont worry about bottlenecks, truthfully Ill probably upgrade in a year or two to an i5 or something similar. I think the gtx 960 gigabyte g1 edition will be good for this. looks really nice.
I also dont need 100fps, 30min and 60-70 max is fine, my monitor is 60hz anyways. thanks for the help guys
