I've been playing Warframe since I built my PC, and was wondering why sometimes the FPS drops. My screen is 16ms response, but sometime is shows up as 25ms and Vsync adjusts. Don't know why. The game is running on ultra, BTW. With Vsync turned off I don't get this kind of error, but I see no reason for my GPU to have to work that much just so I can get that extra 150 frames that I'll never see because with Vsync off I get 150 minimum framerate, about 280 max framerate on ultra.
Normal FPS (look in the lower left corner:
post-182571-0-68634500-1422410682_thumb.
Now messed up FPS
post-182571-0-42224500-1422410712_thumb.
https://linustechtips.com/topic/299559-random-frame-rate-drops-in-warframe/
Its warframe I have the same issues with my SLI 770's its normal.
|King Of The Lost|
Project Dark: i7 7820x 5.1GHz | X299 Dark | Trident Z 32GB 3200MHz | GTX 1080Ti Hybrid | Corsair 760t | 1TB Samsung 860 Pro | EVGA Supernova G2 850w | H110i GTX
Lava: i9 12900k 5.1GHz (Undervolted to 1.26v)| MSI z690 Pro DDR4| Dominator Platnium 32GB 3800MHz| Power Color Red Devil RX 6950 XT| Seasonic Focus Platnium 850w| NZXT Kraken Z53
Unholy Rampage: i7 5930k 4.7GHz 4.4 Ring| X99
Rampage|Ripjaws IV 16GB 2800 CL13| GTX 1080 Strix(Custom XOC Signed BIOS) | Seasonic Focus Platinum 850w |H100i v2
Revenge of 775: Pentium 641 | Biostar TPower i45| Crucial Tracer 1066 DDR2 | GTX 580 Classified Ultra | EVGA 650 BQ | Noctua NH D14
Poorly optimized game, I don't think you are the only person with this issue. Even with my hardware it stutters, I can't stand playing it. Had to uninstall after a couple days.
Ryzen 3700x -Evga RTX 2080 Super- Msi x570 Gaming Edge - G.Skill Ripjaws 3600Mhz RAM - EVGA SuperNova G3 750W -500gb 970 Evo - 250Gb Samsung 850 Evo - 250Gb Samsung 840 Evo  - 4Tb WD Blue- NZXT h500 - ROG Swift PG348Q
Oh ok thanks just hope they get this issue fixed. Actually, Warframe is buggy, but well optomized. An AAA game with the same graphics quality would run like shit on any system. I only can't go higher because of the 300fps frame rate cap.
