Do you have new sticks in your system now?
https://linustechtips.com/topic/29945-pc-problem/#findComment-382573
Try re-seating the RAM.
That means taking it out and putting it back in. Then do a test boot. If it still doesn't work, make sure you didn't leave anything undone (wires, and the like).
† Christian Member †
For my pertinent links to guides, reviews, and anything similar, go here, and look under the spoiler labeled such. A brief history of Unix and it's relation to OS X by Builder.
https://linustechtips.com/topic/29945-pc-problem/#findComment-382589
Tried
Tried re seating the ram and it didn't work. All wires are in because I haven't plugged any of them out. The ram sticks are not new but worked perfectly about a month ago and have been carefully stored away.
https://linustechtips.com/topic/29945-pc-problem/#findComment-382628
Any other compatible RAM laying around?
https://linustechtips.com/topic/29945-pc-problem/#findComment-382634
Perhaps try a different set of RAM.
https://linustechtips.com/topic/29945-pc-problem/#findComment-382662
So they're not functional?
https://linustechtips.com/topic/29945-pc-problem/#findComment-382719
I think this happend to me when I tried to put a 8Gb ram stick into the slot but my mobo only can handle 4 in a slot. Do you know if your mobo supports that ram?
Dell Inspiron 580 - Modified
Build log
Win 7 | GTX 760 | i5 CPU 650 @ 3.20GHz | 2x2Gb 1333MHz Hyundai + 2x2Gb 1333Mhz Crucial RAM | Seagate 1TB 7200RPM | HyperX Fury 120Gb | Corsair Builder 600M | Fractal R2 Mini
https://linustechtips.com/topic/29945-pc-problem/#findComment-382922
