LED Fans in 450D
AJR
Does anyone have a 450D with Corsair LED Fans within it? Please send me pictures, deciding whether or not I should get the clear LED fans or the fans with the cool color accent,
As a Z11 owner:
I advise you to use non-LED Fans.
The light will get annoying and the normal Corsair fans have the perfect touch of color a build would need.
Thanks for the quick reply.
LED fans don't always look the greatest as the light isn't even.
I suggest getting fans that match your build then buy a LED strip. You can always remove the strip if you get tired of LEDs.
blackshades on
This ^^^
Buy the best performing fans then worry about lighting because you can make much nicer lighting effects with LED strips, backlit mid plates and other snazzy stuff like that.
I am addicted to building gaming PCs but I don't have a great reason to stop...yet...
LED fans do look pretty sweet in the front.
post-162296-0-15901400-1422249358_thumb.
More pics here: http://linustechtips.com/main/topic/183-show-off-your-setup/?p=4052500
As the others have said the LED fans can get annoying at times, like if you're watching a movie in the dark.  I'm running 4x intake and 2x exhaust, combining the stock case fans with the LED fans I purchased.  I've set up a media fan profile in AI Suite for watching movies/TV in the dark where only the bottom intake is running (led intake fans are off) and the top exhausts only start up (at very low RPMs) when necessary to exhaust hot air.
CPU Intel Core i7 7700K; Cooler Cryorig R1 Universal; MB Asus ROG Maximus IX Code; RAM G.Skill Trident Z 3200Mhz (4 x 8GB); GPU ASUS GTX 1080 Ti ROG Strix Gaming OC; Case Be Quiet Dark Base 900 Pro Silver; Storage Samsung 960 EVO 500GB, Samsung 850 EVO 1TB, Seagate Barracuda 4TB; PSU EVGA Supernova 850W G2; OS Windows 10; KB Corsair K70 (MX Brown); Audio O2 & ODAC, Sennheiser HD 600, Sennheiser RS 185, Swan M200MKIII; Monitors 2x Dell U2410
Previous Build
CPU Intel Core i5 4690K; Cooler Cooler Master Hyper 212X; MB Asus Z97-A; RAM G.Skill Sniper (2 x 4GB); GPU 2x Gigabyte GeForce GTX 970 G1 Gaming (SLI); Case Corsair Obsidian 450D; Storage Samsung 840 EVO 120GB, WD Black 1TB, Hitachi 750GB; PSU EVGA Supernova 750W G2; OS Windows 10;
