Nexus 120?
CPU:AMD FX-8320, RAM:Kingston Fury Black Series 8GB (1 x 8GB) DDR3-1600, GPU:MSI Radeon R9 280, Case:Cooler Master 690 III, PSU:Thermaltake Smart 650W
Storage:WD Purple 1TB, CPU Cooler:Hyper 212 EVO, Keyboard:SCI Granite, OS:win 8.1 64bit, Display:Samsung SyncMaster SA100, Mouse:CM Storm Spawn
https://linustechtips.com/topic/298116-led-120mm-fan/#findComment-4046757
I belive this one is the quietest with led:
Cooler Master SickleFlow 120mm
2000 RPM, 69.69 CFM, 19 dBA
Air pressure 2.94 mmH2O
No it's not good.
Aerocool ds 120
Ap121 led
https://linustechtips.com/topic/298116-led-120mm-fan/#findComment-4054263
No it's not good.
Aerocool ds 120
Ap121 led
did you ever use Cooler master sickleFlow X 120mm LED?
CPU: i7 4790K | Ram:Corsair Vengeance 8GB | GPU: Asus R9 270 | Cooling :Corsair H100i | Storage : Intel SSD, Seagate HDDs | PSU : Corsair VS 550 | Case: CM HAF Advanced.
https://linustechtips.com/topic/298116-led-120mm-fan/#findComment-4064886
did you every use Cooler master sickleFlow X 120mm LED?
no. beacuse i didnt want to buy something that got reviews saying it was loud and bad.
https://linustechtips.com/topic/298116-led-120mm-fan/#findComment-4064898
Use it. you will bash the face of people saying its loud and bad. buy X version . i found it better then corsair SP12O in noise airflow and Static pressure. even LED is much better then coresair and Arctic fans .
i accidentally bought one and then i've changed every single fan with Sickle flow X blue LED fans . These are hell of a quite fans even on 100% RPM.
https://linustechtips.com/topic/298116-led-120mm-fan/#findComment-4064972
The Tricool red's are really cool. I've had my blue set for 5 years now, I've only had to oil them once. 3 selectable speeds. 4 left in stock and on sale, free shipping. $8.50, great reviews too.
http://www.amazon.com/Antec-TriCool-LED-Cooling-3-Speed/dp/B00066FH7O
My Rig- CPU: Phenom II X4 955 3.2@3.6ghz (OC) Motherboard: MSI 790FX-GD70 Ram: 2x4GB Patriot Viper 1333@1666Mhz (OC) Cooling: Corsair H55 liquid cooler (CPU), 3x120mm 3 speedTricool blue LED case fans (2 front 1 rear), 1x200mm 3 speed Tricool turbine (top)  PSU: Corsair CX600  GPU: XFX R9 270X 1050@1150 (OC) Storage: 1x60gb OCZ Vertex III (Boot) 1x500GB Western Digital Black (Storage) Keyboard: Roccat ISKU Alien FX Multicolor  Mouse: Roccat Cone Pure Multicolor  Headset: Logitech G430 Display: LG Flatron W2353V
https://linustechtips.com/topic/298116-led-120mm-fan/#findComment-4075317
