I have the R7 260X 1GB core edition and after seeing Linus his video about thermal compound and how it can be bad on cheaper cards. I realized I have one of the cheapest R7 260X cards on the marked, so I wanted to know if mine can have some bad thermal compound on it.
After running FurMark for 4 minutes at 100% fan speed my card was up to 87C so I stopped the test.
What are your temps on the R7 260X and what model do you have?
Thank's for the help
https://linustechtips.com/topic/297928-temps-r7-260x/
I don't have a 260x but I am sure that the temps are a bit high
CPU:AMD FX-8320, RAM:Kingston Fury Black Series 8GB (1 x 8GB) DDR3-1600, GPU:MSI Radeon R9 280, Case:Cooler Master 690 III, PSU:Thermaltake Smart 650W
Storage:WD Purple 1TB, CPU Cooler:Hyper 212 EVO, Keyboard:SCI Granite, OS:win 8.1 64bit, Display:Samsung SyncMaster SA100, Mouse:CM Storm Spawn
https://linustechtips.com/topic/297928-temps-r7-260x/#findComment-4044361
87C for a card of that caliber is not good.
Intel Core i7-5820K (4.4 GHz) | Gigabyte GTX 970 G1 Gaming | Corsair Vengeance LPX 16GB  | 2x 360mm Custom Loop (Noctua iPPC) | ASRock X99 Extreme6 | Samsung 840 EVO 250GB | Fractal Design Define S | Corsair HX750 | Windows 10 | Corsair M65 RGB PRO | Corsair K70 RGB LUX (CherryMX Brown) | Beyerdynamic Custom One Pro & Creative Sound Blaster Z | Nexus 6P (32GB Aluminium) | Check out my setup: Project Kalte Here!
https://linustechtips.com/topic/297928-temps-r7-260x/#findComment-4044365
Haven't tried furmark yet but full load temps on mine sit between 60-70C (32-40C ambients) using a custom fan curve...
I'm using a Sapphire R7 260X OC 2GB DDR5 2x DVI (the longer one) at 1250MHz core and 1800MHz VRAM clocks...
https://linustechtips.com/topic/297928-temps-r7-260x/#findComment-4044384
Let's not forget FurMark is meant to stress cards impossibly hard. You'll never hit that in daily use. What are your load temps on actual gaming runs?
When gaming I hit temp of about 70C with my custom fan curve
https://drive.google.com/file/d/0BzF_sB8pF3qiT0pnRHBOSzNvMEE/view?usp=sharing
That's very high. Maybe replace thermal paste and under-clock?
Is your case airflow good?
I am using the Corsair 230T with all 3 fans at about 40% / 45%
The cooler is quite small. The heat sick is only under the fan
https://linustechtips.com/topic/297928-temps-r7-260x/#findComment-4044500
Try testing using Heaven Benchmark and Valley Benchmark.
Haven't tried furmark but used both Heaven and Valley...
Same readings... Highest temp it reached was 71C on my custom curve... (can't run tests again right now... I'm not at home...)
I'm using this card to be exact:
11222-00_R7_260X_2GBGDDR5_DP_HDMI_2DVI_P
https://linustechtips.com/topic/297928-temps-r7-260x/#findComment-4044542
That is quite a bigger cooler then the one I have. I don't know your fan curve but if it is not really slow then my temps don't look that high
https://linustechtips.com/topic/297928-temps-r7-260x/#findComment-4044553
Furmark is a stress test software right? Maybe your GPU temperatures becomes high because the usage is very high, you should try playing some games. Maybe the GPU runs cooler, or just bump the fan speed to the right (not curve one), it makes the GPU louder but at least it helps the GPU cooler because the fan speed runs at full speed at all times.
Where I hang out: The Garage - Car Enthusiast Club
My cars: 2006 Mazda RX-8 (MT) | 2014 Mazda 6 (AT) | 2009 Honda Jazz (AT)
PC Specs
Indonesia
CPU: i5-4690 | Motherboard: MSI B85-G43 | Memory: Corsair Vengeance 2x4GB | Power Supply: Corsair CX500 | Video Card: MSI GTX 970
Storage: Kingston V300 120GB & WD Blue 1TB | Network Card: ASUS PCE-AC56 | Peripherals: Microsoft Wired 600 & Logitech G29 + Shifter
Australia
CPU: Ryzen 3 2200G | Motherboard: MSI - B450 Tomahawk | Memory: Mushkin - 8GB (1 x 8GB) | Storage: Mushkin 250GB & Western Digital - Caviar Blue 1TB
Video Card: GIGABYTE - RX 580 8GB | Case: Corsair - 100R ATX Mid Tower | Power Supply: Avolv 550W 80+ Gold
https://linustechtips.com/topic/297928-temps-r7-260x/#findComment-4044567
For now, try cleaning out the dust, removing your side panel and pointing a fan at the card... see if that improves temps...
Case airflow can also affect GPU temps...
https://linustechtips.com/topic/297928-temps-r7-260x/#findComment-4044578
In game's the temperatures is about 70C with my custom fan curve witch you can see here: https://drive.google.com/file/d/0BzF_sB8pF3qiT0pnRHBOSzNvMEE/view?usp=sharing
https://linustechtips.com/topic/297928-temps-r7-260x/#findComment-4044591
In games the temperature is about 70C with my custom fan curve witch you can see here: https://drive.google.com/file/d/0BzF_sB8pF3qiT0pnRHBOSzNvMEE/view?usp=sharing
https://linustechtips.com/topic/297928-temps-r7-260x/#findComment-4044606
When you open MSI Afterburner, you should see the fan setting (slider). Set the auto off and bump the fan speed all the way to the right (100), if you don't mind the noise. That's what I'd do to my GPU if my room is warmer than usual.
PC Specs
Indonesia
Australia
https://linustechtips.com/topic/297928-temps-r7-260x/#findComment-4044709
