Which case of these is the best in terms of body strength, fans that come with it, cable management and of course shape and LEDs
Corsair 780t
thermaltake level10 gt
Nxzt (whatever the letters are) phantom 530
I like the thermaltake for its leds that change color and fan control but its more expensive than the rest..
I like the corsair because i heard their fans are better
And i like the phantom because it is cheaper, looks smooth.
I watched reviews about 3 of them and all of them are good..
SO WHICH ONE SHOULD I CHOOSE OR UF U HAVE A BETTER ONE IN SAME PRICE RANGE PUT IT HERE
https://linustechtips.com/topic/297909-best-case/
Corsair 780t
The 780T is a great case but you shouldn't choose it just because it has corsair fans, you can buy those on their own.
The phantom is good and if you want the phantom look go cheaper and get a 240.
 idk about the ThermalTake
May i suggest HardwareCanucks on Youtube they do great reviews.
I3-4150 | Be Quiet! Dark Rock Pro 3 | 8GB KINGSTON FURY RAM | MSI Z97-G43 | HYPERX FURY 120GB SSD SAPPHIRE HD7950 VAPOR-X | Phanteks Enthoo Pro M | EVGA 500W | Corsair SP120's w/ NZXT Fan Hub
Plans: I5-4690K || EVGA GS 650W | KINGSTON FURY 8GB RAM  PCPARTPICKER: https://uk.pcpartpicker.com/
https://linustechtips.com/topic/297909-best-case/#findComment-4044021
- Corsair fans aren't very good imo much, there are better and cheaper alternatives about.
- Thermaltake quality is always just under average from me and my friends experiences.
- NZXT Phantom is a good choice if you like the styling I don't have any major issues with it.
Also incoming spwath that will tell you the FT05 :D
My Rig : Zotac 780 3GB, i5 4670k, H105, M1211 650W, 8GB 2133mhz vengence pro, Mini R2, 144Hz AOC Gsync Monitor
Accessories : K65, Naos 3200, Superlux 681, Chord CCU1
https://linustechtips.com/topic/297909-best-case/#findComment-4044466
Get the ft05!
For less money, enthoo luxe.
For even less, s340
https://linustechtips.com/topic/297909-best-case/#findComment-4045522
