you kinda wanna buy the "best" cooler, but that said with the silicon lottery it could be that the cooler is by far the best but the GPU still OCs like nothing
CPU: Xeon 1230v3 - GPU: GTX 770  - SSD: 120GB 840 Evo - HDD: WD Blue 1TB - RAM: Ballistix 8GB - Case: CM N400 - PSU: CX 600M - Cooling: Cooler Master 212 Evo
Update Plans: Mini ITX this bitch
Best OCer would be the HOF card.
It is the 970 out of the box and being a HOF it can go far.
1) Dont buy 970
2) buy 290X or wait for the 3xx series
3) be happy
I say that because of the memory issue, and I am not going to recommend a 970 to anyone until nvidia fixes this.
When they do fix the problem, I'd get a G1 Gaming from gigabyte. They have an awesome cooler and a process for picking out the best overclocking chip.
4790k @ 4.6 (1.25 adaptive) // 2x GTX 970 stock clocks/voltage // Dominator Platnium 4x4 16G //Maximus Formula VII // WD Black1TB + 128GB 850 PRO // RM1000 // NZXT H440 // Razer Blackwidow Ultimate 2013 (MX Blue) // Corsair M95 + Steelseries QCK // Razer Adaro DJ // AOC I2757FH
What is the gtx 970 memory problem???
Basically, a problem with the 4gbs of memory. According to Linus, the problem is that after getting to 3.5gb of Vram usage, the memory goes a lot slower than normal, causing frame rate drops.
But that's a pretty weird instance. No official word from Nvidia, aside for "looking at it". Also, it's a lot like coil whine, in a sense that not all cards are affected by it in the same way (some are worse, some aren't).
Want to help researchers improve the lives on millions of people with just your computer? Then join World Community Grid distributed computing, and start helping the world to solve it's most difficult problems!
Just a question should i wait the R9 390X (or R9 380X) or buy gtx 970.
If you plan on buying something soon, I think it's worth going for the 970. According to AMD, new stuff is coming in Q2 2015, but that's still a bit far away. It might get delayed, it might not be all that better than what we have now, it might be super expensive, (it might have a 300W tdp) who knows?
And when we get the 3xx series, there might just be a "980ti is coming in a few months!" announcement, and then we are back at the "should I wait?" question.
Do you can help me i have a GTX 760 and i want to upgrade should i go GTX 970 or i go R9 300 series i have 400€ (i think 450$) budget??? What i choose??? i want to upgarde before the summer holiday.
PC specs plz.
X79 deluxe I7 4820K
Uh.... With that kind of setup, you could actually go for a much higher GPU config than a 970. Grab the cheapest 970 you can find out of these 4:
  1. MSI Gaming 4G
  2. Gigabyte Windforce OC
  3. Gigabyte G1 Gaming
  4. Asus Strix
Then, when you get some extra money laying around, get a 2nd 970. Maybe when the 3xx launches, 970 prices should drop.
R9 300 will be out very soon, but we don't know much about it just like what you know.
GTX970 is currently a great upgrade right now, I think Nvidia will fix that shame mem issue soon but I never see my mem usage goes beyond 2GB (coz i'm 1080p user)
Primary PC
CPU: AMD Ryzen 7 5700X3D | GPU: Zotac RTX 3080Ti 12GB | M/B: Asus ROG Strix X370-F | RAM: Corsair Pro SL 3200MHz 32GB | SSD: WD Black SN7100 1TB / Samsung 870 Evo 1TB | HDD: Seagate EXOS X16 16TB x2 | Power: Corsair RM850e | Sound card: Creative Sound BlasterX AE-5  | Case: NZXT H500 | Cooling: NZXT Kraken X62 | Display: Samsung QLED 27" 2K 144Hz VR: Pico 4
Secondary PC
CPU: AMD Ryzen 5 5600 | GPU: Asus RTX 4060 8GB | M/B: Asrock B450M Pro 4 | RAM: HyperX Fury 3200MHz 32GB | SSD: Crucial P1 1TB | HDD: WD Black 1TB | Power: Coolermaster Masterwatt 550 | CaseAerocool Cylon Mini | Cooling: BeQuiet Pure Rock Slim 2 | Display: Samsung QLED 24" FHD 144Hz VR: Meta Quest 2
Thanks for reading
