Front Panel: No Bass
Go to solution Solved by Dixon,
solved it. confusingly, the ground has to connected to the pin next to it which should be analog vcc power =)
hi guys, after getting some sleeving for my rig, the front panel audio ist kind of weird. it doesnt put out bass any more, so when listening to music i will hear voices and percussion stuff like hihats etc, but no bass at all. i'm running a sabertooth z77 in a corsair 600t case. during the sleeving process i removed the AC97 connector. in bios the sound is set to hd audio. i noticed that the second pin of the hd audio connector (GND) of the case does not have a cable running to the front panel. it only ran to the AC97 connector. i'm quite confused.
anyone got any idea? thanks in advance (=
https://linustechtips.com/topic/29718-front-panel-no-bass/
well, you don't have a ground connection.
that causes it to sound funny.
did it get caught in the sleeving?
Will work for electronic components and parts
Reviews: Meelec CC51P - Monoprice 8323 - Koss Porta Pros  - Shure SRH-440 - Shure SRH-550DJShure SRH-840 - Hifiman He-500 - iBasso D4 - o2 Amplifier  -  SkeletonDac
https://linustechtips.com/topic/29718-front-panel-no-bass/#findComment-379561
nope, removed the sleeving and i just cant find that freaking ground cable. i took of the front panel to see all the cables running in there, and there are actually only the cables which are in the hd audio connector. i just dont get it. this is kind of frustrating, but still amusing  :wacko:
https://linustechtips.com/topic/29718-front-panel-no-bass/#findComment-379584
did it accidentally get pulled out entirely?
stuck in the old sleeving?
https://linustechtips.com/topic/29718-front-panel-no-bass/#findComment-379607
