Hey! I do a slightly overclock on my gpu but all the games crush after 10-15 minutes gameplay do you know any solution?
MY PC   CPU INTEL i7 4790k   MOTHERBOARD ASUS SABERTOOTH Z97 MARK1   COOLING CORSAIR H80i    CASE BITFENIX RONIN   RAM 2X4GB CORSAIR VENGEANCE 1600MHZ  GPU GIGABYTE GTX 970 G1 PSU CORSAIR RM750 WATT SSD SAMSUNG PRO 850 256GB HDD WD 1TB BLUE
https://linustechtips.com/topic/296516-overclock-gtx-970-g1-problem/
1. Check to make sure the power limit is set as high as possible
If it's not, set it as high as possible. This will most likely fix the problem.
2. If it is already set as high as possible, back off on your overclock or add more voltage. The card is probably exceeding its power limit.
3. If the card simply will not overclock, you either have a "bad" card or poor power delivery from the PSU.
Atom14 [Corsair] i5-4690K | Corsair H110i GT | MSI Z97S SLI Krait | 16 GB Team Group DDR3 | Samsung 850 EVO 250GB X2 | EVGA SuperNOVA 850W 80+ Gold | Corsair K95 RGB | Corsair M65 RGB | EVGA ACX 2.0 GTX 980Ti
Corsair KXX RGB Keyboard Cover Mod Make your own using my templates!
No it will not
Not increasing the power limit will simply mean the card will throttle due to lack of power, it will not cause crashing
Again, not true
Poor PSU power delivery would not just cause games crashing after 10-15 but it would much sooner cause an entire pc reboot
RIG: I7-4790k @ 4.5GHz | MSI Z97S SLI Plus | 12GB Geil Dragon RAM 1333MHz | Gigabyte G1 Gaming GTX 970 (1550MHz core/7800MHz memory) @ +18mV(Maxed out at 1650/7800 so far) | Corsair RM750 | Samsung 840 EVO 120GB, 1TB Seagate Barracuda | Fractal Design Arc Midi R2 (Closed) | Sound Blaster Z        Getting: Noctua NH-D15 | Possible 250GB Samsung 850 Evo        Need a console killer that actually shits on every console? Here you go (No MIR/Promo)
This is why you should not get an FX CPU for ANY scenario other than rendering on a budget http://linustechtips.com/main/topic/286142-fx-8350-r9-290-psu-requirements/?p=3892901 http://linustechtips.com/main/topic/266481-an-issue-with-people-bashing-the-fx-cpus/?p=3620861
I used EVGA Precision X to overclock my 970 G1 Gaming. I suggest you start low with Power limit set at 112%, GPU +100 and MEM +100 and work your way up. Run Unigine Heaven benchmark to stress the GPU. I got +210 mhz on the GPU and +250 on the MEM on my card. :)
#LinusKitchenTips /// "Better than useless" - Linus Sebastian
LTT Holy bible: Code Of Conduct
Project Toaster [My Silver NCASE M1 V2 Build-log]
Main Rig
 Case: Fractal Design Define R5 CPU: INTEL
i5 3570k Cooler: CM Hyper 212 Evo Mobo: Maximus V Gene Z77 GPU: Gigabyte GTX 970 G1 Gaming (w/ 0% fan mode) RAM: Corsair Dominator Platinum 2x8GB 1600mHz Storage: OCZ VERTEX 4 256GB PSU: Corsair AX860 Monitor: ASUS PB278Q 1440p 27" Headphones: QPAD QH-90 Laptop
Macbook Pro Retina 13" i5 256Gb Early 2015
Phone
Oneplus One 64GB Sandstone Black
No it will not
Again, not true
well then my experience has lied to me :/
I swear, this is how I fix all my overclocking problems.
If a card exceeds the power limit unexpectedly, it will down clock immediately and restore its overclock as soon as the overcurrent situation has passed, which can cause a game to crash because the software expects to run smoothly. Same thing with a power supply. Hardware has these safety features built in, but the software typically does not.
Poor power delivery can crash graphics drivers without crashing the whole PC, especially if the PSU is struggling top supply enough power to feed the overclocked system.
i add more voltage but the same and especially on Shadow of mordor i've an error that i dont have enough ram ...
I think you've simply got a bad chip. What are your numbers?
power target max
gpu clock 100
memory 100
That seems with in reason, unless you're pushing your voltages high?
Im not pushing that high but i add more voltage...
I believe voltages can cause crashes/instability... not too sure what the deal is. May just not be the best overlocker.
it does the same without more voltage
You said you made an overclock so if nothing works just go back to default clock.
that is what im gonna do
Ouch, i dunno what to say mate :L
fuck it i'll leave it to normal
well i think my gpu is trolling me...after a restart i finally stable it at 130 at gpu clock and 150 memory...
