So I've had this computer for several months now (My first actual PC not being a laptop) and I was wondering what to upgrade first since, apparently, games are already going past these for recommended! I'm not upgrading until the summer though, just need a general idea of which I should go by, here's my build (https://pcpartpicker.com/b/ZCwV3C). I do want to get a mid tower, looking at corsair 450D or fractal design R5 so if that helps in any way I just wanted to put that out there.  :D
https://linustechtips.com/topic/295681-what-to-upgrade-first/
Probably the CPU and perhaps the mobo to whichever you feel is best for you. Take a look at AMD and see what fits in your price range. Everything else should carry over, just make sure to only buy an ATX board and nothing larger.
Happy upgrading!
Dual Boot Windows & Hackintosh
CPU: Intel 4790K | Motherboard: ASUS Maximus Hero Vii | GPU: Zotac AMP! Extreme GTX 970 | Display: ASUS PB278Q | Case: Phantom 630 | PSU: Corsair HX1000i
Canada eh?
https://linustechtips.com/topic/295681-what-to-upgrade-first/#findComment-4014207
Definitely the CPU. Buy the best processor for your motherboard's socket. I don't know much about AMD, so I can't recommend a CPU. A case should be the last thing on your mind for upgrades right now though, unless you have a lot of money to throw around.
CPU i5 3570k MOBO Asus Maximus Gene V GPU Asus DCUII 670 CASE Corsair 350D (windowless) SSD Crucial M550 256GB msata CPU COOLER Noctua NH-D14 RAM Corsair XMS3 8GB 1600mhz PSU Corsair AX750 Display Asus PB287Q 4K (my review on it http://linustechtips.com/main/topic/380533-journey-into-4k-goodness-asus-pb287q-review/) & Asus VH236H 1080P
Keyboard Logitech G710+ MX Brown Mouse Logitech G502 (my review on it http://linustechtips.com/main/topic/299464-logitech-g502/ )
Proud owner of a BlackBerry Q10.
https://linustechtips.com/topic/295681-what-to-upgrade-first/#findComment-4014218
