is it worth replacing my stock h110 fans with a pair of Noctua NF-A14 FLX 140mm?
Or will the difference be negligable?
Cpu: Intel i7-5930k Mobo: Asus Rampage V Extreme Ram: G.skill Ripjaws 4 4x4gb 2666mhz Gpu: Gigabyte GTX 970 G1 Gaming
PSU: Evga Supernova G2 850W Storage: Samsung 850 Pro SSD 512gb Case: Phanteks P400S CPUcooler: Corsair H110 OS: Win 8.1
https://linustechtips.com/topic/295365-replacing-h110-fans/
yes the if its the old style gray fans
What reasoning do you have for this statement?
Sometimes i troll...
3D Mark Fire Strike Score: http://www.3dmark.com/fs/3854240 +215mhz Core Clock +440mhz Memory Clock @4.6ghz 1.325v
http://pcpartpicker.com/user/b1aze/saved/qQFxFT
https://linustechtips.com/topic/295365-replacing-h110-fans/#findComment-4010084
I don'trecommend that model. I actually reccomend the industrial PPC 3000RPM version of the NF-12 series. They CAN be loud as heck, but they work so efficienty that they will never have to ramp up that high. they provide the same airflow as the stock fans on the h110 at 26.5 dBa. And if something goes wrong, the fans can ramp up and get it back down to a safe temp.
Feel free to PM with any more questions!
4790k @ 4.6 (1.25 adaptive) // 2x GTX 970 stock clocks/voltage // Dominator Platnium 4x4 16G //Maximus Formula VII // WD Black1TB + 128GB 850 PRO // RM1000 // NZXT H440 // Razer Blackwidow Ultimate 2013 (MX Blue) // Corsair M95 + Steelseries QCK // Razer Adaro DJ // AOC I2757FH
https://linustechtips.com/topic/295365-replacing-h110-fans/#findComment-4010107
i think theyre, black, eitherway, its the stock ones that comes with the h110
what should i expect if i switch?
https://linustechtips.com/topic/295365-replacing-h110-fans/#findComment-4010142
There loud for a 140mm fan, they are ugly , and they are not as good as the Noctua Fans
they are noctuas... just more basic and cheaper
Are you new to the forums???? read the Code of Conduct HERE WANT SOME AWESOME LTT THEMED WALLPAPERS??? check out XTanksSlayerX's wallpaper thread HERE
"May our framerates be high, and our temperatures low" - PC MasterRace
https://linustechtips.com/topic/295365-replacing-h110-fans/#findComment-4010144
less noise and/or lower temps
https://linustechtips.com/topic/295365-replacing-h110-fans/#findComment-4010150
Can you quantify WHY they are better than the corsair fans? Yes, I can see that they technically flow more air, but in the real world application, it wont make a difference.
I can guarantee you that OP will see a literally negligible performance gains out of different fans on the H110. I get no difference in cooling temps from Quiet to Performance mode on my H80i, which means increasing airflow != cooler temps.
https://linustechtips.com/topic/295365-replacing-h110-fans/#findComment-4010170
ok, that pricing tho :/
https://linustechtips.com/topic/295365-replacing-h110-fans/#findComment-4010186
ok, so not worth it then?
https://linustechtips.com/topic/295365-replacing-h110-fans/#findComment-4010197
duh, but is the difference worth it?
https://linustechtips.com/topic/295365-replacing-h110-fans/#findComment-4010222
Yeah, it's a bit steep....
But it's a good investment. The warranty is like what, 6 years? You can reuse these fans in several future builds. Believe me, the cost is justified by the quality and performance,
https://linustechtips.com/topic/295365-replacing-h110-fans/#findComment-4010227
I bet your H80i sound like a Jet engine thought and your cooler has 120mm fan on it not 140mm
https://www.youtube.com/watch?v=pSBX2pwEDDA
https://linustechtips.com/topic/295365-replacing-h110-fans/#findComment-4010229
I personally dont think that its worth it unless youre doing it for the noise reduction alone. It would be very difficult to get better cooling performance from an extra few CFM of airflow on such a big radiator.
https://linustechtips.com/topic/295365-replacing-h110-fans/#findComment-4010240
On Quiet mode, my GPU is actually louder under load than the H80i. I have tried both Quiet and Performance mode and i get less than .5C difference in average coolant temp, and zero difference in average CPU temp from both modes. If i HAD to run Performance mode, yes, it would be loud as hell but Quiet mode is just as efficient and performs very well.
FYI, im running 4.7ghz @ 1.385V on my i5-4670K
https://linustechtips.com/topic/295365-replacing-h110-fans/#findComment-4010262
also you have to take in effect that your cooler unlike the H110 is set up in push pull ware as the H110i is only one or the other
https://linustechtips.com/topic/295365-replacing-h110-fans/#findComment-4010286
Its also twice as thick of a radiator.
I would be very curious to see if anyone has done a side-by-side comparison of cooling performance between stock fans and aftermarket fans. I would be incredibly surprised to see if there was even a 1*C average difference in CPU temps, and for $50 fan investment, thats a very very small gain.
https://linustechtips.com/topic/295365-replacing-h110-fans/#findComment-4010302
I agree its more then likely a small gain if any, and the noise is not that bad, but they do look ugly unless your case some how matches it. and the noctua fans, well there not so pretty them self,  so personally i wouldn't spend the money.
I would spend the money on some nice looking corsair SP fan though but mainly for ascetics and that's all. Puls there half the price.
I purchased Noctia fans 1 time thinking they might match my tan system but the tanish color on them is almost a gross pink and matches nothing.
https://linustechtips.com/topic/295365-replacing-h110-fans/#findComment-4010363
ok, so no go then.
if i were to use the three remaining fanspots in my 750d, which fans should i get then?
1 140mm(third fanspot in ceiling) and 2 120mm(bottom)
just corsair af fans?
https://linustechtips.com/topic/295365-replacing-h110-fans/#findComment-4010483
ok, so no go then.
The FZ series from NZXT is great. I have one of the 140mm red LED fans and it's stellar.
120mm LED: http://www.nzxt.com/product/detail/93-fz-120mm-led-case-fan
120mm : http://www.nzxt.com/product/detail/94-fz-120mm-non-led-case-fan
140mm LED: http://www.nzxt.com/product/detail/115-fz-140mm-led-case-fan
140mm: http://www.nzxt.com/product/detail/116-fz-14mm-nonled-case-fan
https://linustechtips.com/topic/295365-replacing-h110-fans/#findComment-4010855
I got some of Noctua's 1200rpm Grey redux fans for my h110, Much quieter at lower speeds and the move just as much air, temps didn't change much. I found mine for $13 a piece which made them a steal. Asides from the colour I don't know why anyone would buy the Industrial fans or recommend the industrials at almost twice the list price of the Redux fans and much louder when typically the reason to ditch the H110 fans is to reduce noise. The special features (higher RPM, water-proofing, better motors, etc) are just not required for simple RAD fans.
There are other fans out there though and at the end of day they are all very similar in noise and airflow.
Corsair 400C- Intel i7 6700- Gigabyte Gaming 6- GTX 1080 Founders Ed. - Intel 530 120GB + 2xWD 1TB + Adata 610 256GB- 16GB 2400MHz G.Skill- Evga G2 650 PSU- Corsair H110- ASUS PB278Q- Dell u2412m- Logitech G710+ - Logitech g700 - Sennheiser PC350 SE/598se
Is it just me or is Grammar slowly becoming extinct on LTT?
https://linustechtips.com/topic/295365-replacing-h110-fans/#findComment-4013161
